Help with my moates burn 1
Old Sep 29, 2006 | 12:22 PM
Ls_dx's Avatar
Default Help with my moates burn 1
ok, hooked up the driver and the burner, comupter recognizes it because i can do the erase chip function, but when i try to burn a .bin off the buffer, it gives me error messages... please help
Old Sep 29, 2006 | 03:16 PM
Got_soy's Avatar
Default Re: Help with my moates burn 1 (Ls_dx)
you have to read it then check the buffer or something before you burn
Old Sep 29, 2006 | 07:57 PM
mtber's Avatar
Try burning a different bin file.. The file you are trying to burn maybe currupt.
Old Sep 29, 2006 | 09:51 PM
Ls_dx's Avatar
Default Re: Help with my moates burn 1 (mtber)
ok tried that and still nothing... installed it on my pos desktop and it worked perfectly... wtf,.,, nice new laptop doesnt work but pos desktop works,... what gives??
Old Sep 29, 2006 | 10:45 PM
SpdFrk's Avatar
Are u using com ports 1-4 on ur laptop? It will only work threw these ports.
Old Sep 29, 2006 | 10:50 PM
Ls_dx's Avatar
Default Re: Help with my moates burn 1 (SpdFrk)
yes used com port 2,3,and 4, also switched to 5 per craig moates, and still nothing,.. any ideas?
Old Sep 30, 2006 | 09:37 AM
SpdFrk's Avatar
Did u go to the Device manager on your laptop and make your your com ports are properly installed and enabled?
Also did u download the USB files from the moates site?
Old Sep 30, 2006 | 11:14 PM
Ls_dx's Avatar
yea to all above
Old Oct 1, 2006 | 09:00 AM
F20Cteg's Avatar
Try selecting the right type of chip on the left.
Remember, you can only burn the SST's, Atmel, and the 4 meg.
Also, what is the error message?
Old Oct 1, 2006 | 11:21 AM
boosted k20's Avatar
Default Re: Help with my moates burn 1 (F20Cteg)
also i noticed that with my moates burn1, i cant burn a .bin while its still open in a program like crome, uber, or hondata. u can either close the crome, uber, hondate, etc window and burn the program then reopen the crome, uber, etc program. OR u can save the .bin as something else and then program it, just make sure what ur loading into the burn1 and what program is currently open dont have the same name
also try a new chip
Old Oct 1, 2006 | 10:01 PM
Ls_dx's Avatar
Default Re: Help with my moates burn 1 (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F20Cteg &raquo;</TD></TR><TR><TD CLASS="quote">Try selecting the right type of chip on the left.
&gt;&gt;&gt;&lt;&lt;&lt;</TD></TR></TABLE>
its a sst chip and its selected up top.. the error message is: Check firmware and connectivity
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">also i noticed that with my moates burn1, i cant burn a .bin while its still open in a program like crome, uber, or hondata. u can either close the crome, uber, hondate, etc window and burn the program then reopen the crome, uber, etc program. OR u can save the .bin as something else and then program it, just make sure what ur loading into the burn1 and what program is currently open dont have the same name
also try a new chip</TD></TR></TABLE>
there is no other program open and i tried a few diff chips. it will erase chip, but when you blank check or anything else, it gives error message. ive tried all 4 usb ports ... everyuthing.... this sucks
Old Oct 1, 2006 | 11:34 PM
F20Cteg's Avatar
Go to moates.com and get the firmware updater program. Compare the current firmware with what is in your BURN1.
Old Oct 2, 2006 | 08:38 PM
Ls_dx's Avatar
still nothin
Old Oct 2, 2006 | 08:40 PM
khmboostedeh2's Avatar
set latency and baud right? (1 and 7200 i believe)
Old Oct 2, 2006 | 10:29 PM
Ls_dx's Avatar
Default Re: Help with my moates burn 1 (Jeterkm02)
yep got that covered ...
Old Oct 3, 2006 | 02:13 PM
F20Cteg's Avatar
If you are still having trouble, contact Craig Moates. They have the best customer service that I have ever seen.
Old Oct 3, 2006 | 03:41 PM
coneheadsracing's Avatar
Using the same cable on both computers?
Old Oct 3, 2006 | 07:33 PM
Ls_dx's Avatar
Default Re: Help with my moates burn 1 (coneheadsracing)
i spent 30 min on the fone with craig....nothing...
yes same cable on both comps... nothing
Old Oct 4, 2006 | 11:12 AM
F20Cteg's Avatar
Might try a different cable.
I had a USB cable go bad once.
Old Oct 4, 2006 | 09:09 PM
Ls_dx's Avatar
ill try
Extreme191
Dec 26, 2017 10:29 AM
omega_wreck
Aug 13, 2014 08:01 AM
Rocks
Nov 1, 2004 12:41 PM
