why am I boosting different pressures in different gears?
In 2,3,4 gear im boosting 10 pounds, but when Im in 5th and boost it will hit 10. My engine is turbo ls, ls tranny. dsm 450 injectors, t3. ran with uberdata.
Re: why am I boosting different pressures in different gears? (motormike40)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motormike40 »</TD></TR><TR><TD CLASS="quote">In 2,3,4 gear im boosting 10 pounds, but when Im in 5th and boost it will hit 10. My engine is turbo ls, ls tranny. dsm 450 injectors, t3. ran with uberdata. </TD></TR></TABLE>
Your post body contradicts your title? Unless of course first gear differs in boost pressure. If this is the case, it may be advantageous to include it next time. The more information that you can provide us, the more accurate, and prompt responses you will receive.
1-2 gear might boost less then 3-4 gear because of the amount of load on the engine is much less in 1-2 gear compared to 3-4-5 gear
but yeah your saying different boost pressure in the title then saying same boost pressure, explain better
Re: (motormike40)
somewhat normal
not so much on the ls trans tho
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-LS »</TD></TR><TR><TD CLASS="quote">1-2 gear might boost less then 3-4 gear because of the amount of load on the engine is much less in 1-2 gear compared to 3-4-5 gear
DamonBoost
11-22-2001 01:14 PM
