which flywheel for boost opinion..?
Old Sep 28, 2006 | 05:07 PM
tobe1424's Avatar
Default which flywheel for boost opinion..?
I debating wheater to get a 7.5 pound fidanza aluminum flywheel...or for like 20 bucks more... an exedy 9.5 pound cromoly flywheel....id rather go with the exedy one...but any opinions on the fidanza...with my goal of 300whp on an ls i would be afraid to hit fuel cut so fast.... any suggestions HT
Old Sep 28, 2006 | 05:16 PM
vxhatched's Avatar
Default Re: which flywheel for boost opinion..? (tobe1424)
Stock is the best ,it holds up the best ,and balances the crank the best. It gives you more consistent launches. Lightweight is not bad but stock is the best just get it resurfaced to stock specs, throw in a good clutch and you are good to go.
Old Sep 28, 2006 | 05:41 PM
tobe1424's Avatar
Default Re: which flywheel for boost opinion..? (vxhatched)
well the thing is that my motor is auto...so i need to buy a flywheel period...its not because i want to...and a light flywheel on an ls tranny should help out with the long gearing...but not that light neither
Old Sep 28, 2006 | 05:46 PM
inspyral's Avatar
Autos use a flexplate and torque converter, so I don't think any of the aftermarket lightweight flywheels are going to work for you.
Old Sep 28, 2006 | 05:58 PM
tobe1424's Avatar
Default Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">Autos use a flexplate and torque converter, so I don't think any of the aftermarket lightweight flywheels are going to work for you.</TD></TR></TABLE>
dude im putting a manual tranny....removed all that converter **** and moving to manual...so i need a flywheel...just dont know which one of the 2
Old Sep 28, 2006 | 06:01 PM
StckOnHvyChcks's Avatar
You probably just want to go OEM.. from what I've heard they work the best for boost applications
Old Sep 28, 2006 | 07:17 PM
tobe1424's Avatar
Default Re: (StckOnHvyChcks)
but the thing is that every car from factory comes with an OEM flywheel that its balanced to that motor and only that one.... So if i get for example another ls flywheel it will be more unbalanced that if i buy an after market flywheel that its balanced to fit any application
Old Sep 28, 2006 | 07:21 PM
Attaus's Avatar
You don't want too light of a flywheel with boost.. I've seen lots of guys with great results anywhere from 9-12 lbs, but any less is risky IMO.
Old Sep 29, 2006 | 05:06 AM
tobe1424's Avatar
Default Re: (Attaus)
anyone else
Old Sep 29, 2006 | 05:27 AM
troubledsol03's Avatar
Look at it this way a lite flywheel will rev up and down faster the heavy flywheel will rev up and down slower but will have the extra rotating mass to assist your launch
I run an ITR flywheel OEM quality slightly lighter
Old Sep 29, 2006 | 05:31 AM
92redhatch's Avatar
GET A 7.5lb Flywheel!!!!
Old Sep 29, 2006 | 08:44 AM
95dc2teg's Avatar
Getting my clutch today with act prolite flywheel (8.8lbs) i will let you know how it feels. Im boosted at 7psi on a t3/74 57 trim .60 a/r turbo in stock block gsr motor.
Old Sep 29, 2006 | 11:06 AM
Schister66's Avatar
Man U FTW
just use OEM because there are a lot better ways to spend $200+
i got mine new at a good price....ACT 11lb
Old Sep 29, 2006 | 11:18 AM
drintegra's Avatar
Default Re: (Schister66)
I have a friend with the 7lbs exedy flywheel and I have the street version of the competition clutch I think it is 10-11 lbs. I do not feel much difference with either. Stock is pretty heavy and I felt a difference then. I got the exedy that my friend has for like 140, and mine was about the same. The clutch is where the difference is at. I felt a pretty noticeable difference between the CM stage 4 and the Competition Clutch stage 4. The CM is way harsher but it grabs like a mother. If I had a stock Flywheel I would just keep it though and have it balanced and spend the money on the clutch.
Old Sep 29, 2006 | 12:29 PM
95jeremie's Avatar
Default Re: (drintegra)
use the search
this has ben debated thousands of times
my opinion is...
i love my light fly (10lb fadanza)
the response is great
and the RPM's do drop but not to the point to the car cutting out.
rev matching is also easier
Old Sep 29, 2006 | 01:22 PM
RedEj8's Avatar
Default Re:
Since when do flywheels balance the crank?..Thats what the oem crank pulley is for....Get one as light as you want..only thing is it takes a little while to get used to it, and you have to shift faster due to revs dropping faster since the flywheel is lighter.Id say either the fidanza or the exedy would be fine for ur app.
Old Sep 29, 2006 | 02:36 PM
TheShodan's Avatar
Moderator
Default Re: Re: (RedEj8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedEj8 &raquo;</TD></TR><TR><TD CLASS="quote">Since when do flywheels balance the crank?..Thats what the oem crank pulley is for....Get one as light as you want..only thing is it takes a little while to get used to it, and you have to shift faster due to revs dropping faster since the flywheel is lighter.Id say either the fidanza or the exedy would be fine for ur app.</TD></TR></TABLE>
True. Both could work, but I've had several problems with aluminum flywheels with the OEM starter teeth. In which it does create difficult start difficulty because of the different metals. I would use a resurfaced OEM, or an Exedy flywheel.
Old Sep 29, 2006 | 06:05 PM
tobe1424's Avatar
Default Re: Re: (TheShodan)
Ok i dont have a flywheel period...and im not going to buy an OEM one...and not mike...7.5 aluminum ...for some reason it would make me feel better if i have a cromoly 9.5.... but just want recommendations
Old Sep 29, 2006 | 06:08 PM
vg7z's Avatar
does anyone here even HAVE a light flywheel? I hate ppl that dont have 1 and make inputs.
I just put an ACT streetlite 11.5. It runs great. I see no difference in handling, some ppl say it takes effort to get use to getting out the hole and i see no difference.
Revs dont drop faster than before. THey drop normally. You have to be granny shifting to see a fast drop.
Acceleration is great. I can feel a difference in light throttle accel. Also picks up a lot better at WOT.
Id recoomend getting it if u can for cheap.
Old Sep 29, 2006 | 06:28 PM
sirguy01's Avatar
Default Re: (vg7z)
My buddy has the exedy flywheel, he says the response on the car is amazing.. i can vouch for that. However he's not boosted... I'm currently using an OEM R flywheel and its great.. obv heavier than the other ones.. but not a bad bet.
Otherwise just go with the exedy.
Old Sep 29, 2006 | 08:02 PM
tobe1424's Avatar
Default Re: (vg7z)
thanks you man thats the type of stuff ive been wanting to here...and yours too sirguy lol
Old Sep 29, 2006 | 08:30 PM
92redhatch's Avatar
7.5lb fidanza flywheel ftw. Go EXTREME!!! lol
Old Sep 29, 2006 | 08:59 PM
tobe1424's Avatar
Default Re: (92redhatch)
im getting the cromology one from exedy ...i would trust it better than aluminum for boost....
http://www.exedyusa.com/race/HF01
Sir-Boost-Alot
Oct 29, 2005 07:29 PM
kool168
25
Feb 4, 2004 08:45 PM
HUBB
Jan 31, 2004 10:49 PM
p1ccoloz
Jun 3, 2003 10:26 PM
