Looking for 200 WHP
Old Oct 1, 2006 | 05:38 PM
hondacivic995's Avatar
Default Looking for 200 WHP
I have done quite a bit of research on the turbo issue. This will also be my first setup, and I therefore am a noob at this so bear with me. I am looking for a turbo to support my needs for 200 to 220 WHP on a stock d16z6 block, I have located a manifold I like and have selected the Spoolin Perfomance Log Mani for a D series it's externally gated, and comes with a tial 38 mm wastegate. The turbine bolt pattern is either 4 or 5 which i am also unsure of. What turbos am I looking for that fit my setup?
Thanks beforehand
Old Oct 1, 2006 | 05:58 PM
90DALS's Avatar
Default Re: Looking for 200 WHP (hondacivic995)
pretty much any T3, or go with a DSM turbo and weld the flapper shut to use the external gate (what i did with my T25). DSM t25 or 14b will get you your 200wheel.
I Have an STD's Avatar
wrenchin'
t3 42/48 or 48/60. i made 206 with a stock block sohc on a 42/48 on 10 psi. 230 is no problem on these little guys
Old Oct 1, 2006 | 06:01 PM
Tornadom's Avatar
Default Re: Looking for 200 WHP (I Have an STD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD &raquo;</TD></TR><TR><TD CLASS="quote">t3 42/48 or 48/60. i made 206 with a stock block sohc on a 42/48 on 10 psi. 230 is no problem on these little guys</TD></TR></TABLE>
With instant spool, and outrageous tourque to boot.
Old Oct 1, 2006 | 06:02 PM
EK k kay's Avatar
Yeah a T3 .42/.48 will be perfect for 200whp. A T3 .60/.48 which is what I am using will also be good, but will give you a little more headroom in case you want more power. If 300+whp is something you might want then think about the T3/T04E .50 trim or a ballbearing GT28R/RS.
Old Oct 1, 2006 | 06:13 PM
Yeah I may want more power in the late future. But not till 2007 or so the t3 50 trim .42 .48 was what I had been looking at and was reccomended in another forum. I just wanted to get some answers from someone thats already had the experience with the turbo.
Old Oct 1, 2006 | 06:23 PM
Also, what intercooler?, and what size is reccomended for my setup? I know it doesnt have to be big because im not pushing an insane amount of HP but I want quality. No Ebay junk.
Old Oct 2, 2006 | 07:21 AM
broketuner-Sol_Si's Avatar
as for a size, I think something around 30lx6hx2.5w(give or take on the length and width) would be fine(most around that size claim to be good to 250-350whp). For that amount of hp you definatly won't need a huge *** supra IC or something. As for a brand I can't reccomend nor trash any at the moment because I'm pretty much in the same boat as you (got some parts figured out/already have them, just trying to figure else what else it needs to be good/reliable), although I have heard that SOME of the ebay ones are good quality
Old Oct 2, 2006 | 12:13 PM
wrenchin'
Default Re: Looking for 200 WHP (Tornadom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tornadom &raquo;</TD></TR><TR><TD CLASS="quote">With instant spool, and outrageous tourque to boot.</TD></TR></TABLE>
hell yeah, full spool by 3300 and 186 ft lbs of torque!
meagainsttheworld
May 20, 2007 06:40 PM
dturbo
Jan 21, 2006 09:19 AM
crxnj
Dec 22, 2005 10:04 AM
AaronJ
Oct 13, 2005 11:51 AM
DualCamDan
19
Sep 14, 2004 08:35 AM
