log manifold capable of 300whp??
Old Sep 26, 2006 | 03:15 PM
turbo boost's Avatar
Default log manifold capable of 300whp??
i have a lsvtec and was wondering if a log manifold is capable of 300-350whp??
thanks
Old Sep 26, 2006 | 03:19 PM
RCautoworks's Avatar
Default Re: log manifold capable of 300whp?? (snowbunny)
Yep
Old Sep 26, 2006 | 03:27 PM
urbansi's Avatar
Default Re: log manifold capable of 300whp?? (90blackcrx)
I have heard claims of over 600 being made on one, so i wouldnt worry about a measle 300
Old Sep 26, 2006 | 03:32 PM
Default Re: log manifold capable of 300whp?? (urbansi)
awsome
Old Sep 26, 2006 | 03:48 PM
iBrandon's Avatar
very easily!
Old Sep 26, 2006 | 04:45 PM
Danny_EJ's Avatar
i made 400 on a spoolin log
Old Sep 26, 2006 | 06:53 PM
StylishDOHC's Avatar
Default Re: (Danny_EJ)
yep just gotta run a few more lbs. than the ramhorn guys...just make sure your exhaust post-turbo isn't too restrictive.
Old Sep 26, 2006 | 07:05 PM
94hatchvx's Avatar
Default Re: (StylishDOHC)
thats good to hear because i to have a log manifold with my turbo set up and i am upgrading soon hoping for the 400whp+ group. i know its not alot for most but 400whp is alot for me.
Old Sep 26, 2006 | 07:12 PM
93supercoupe's Avatar
Default Re: (94hatchvx)
400 is nothing to be ashamed of, its still going to hual ***, not matter who it is
Old Sep 26, 2006 | 07:29 PM
spooncivic1's Avatar
it will make the power, but the spool time will be alot later
you will see gains pretty much the whole powerband with any manifold that has a merge
Old Sep 26, 2006 | 08:36 PM
Default Re: (spooncivic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooncivic1 &raquo;</TD></TR><TR><TD CLASS="quote">it will make the power, but the spool time will be alot later
you will see gains pretty much the whole powerband with any manifold that has a merge</TD></TR></TABLE>
It's a well known fact that a log will always spool faster then an equal length..
Old Sep 26, 2006 | 08:39 PM
Mag00n's Avatar
Log = quicker spool but less top end
Inline Pro logs have made over 600hp
My inline pro is doing 400+ right now
Basic logs can doo 300 EASILY
Old Sep 27, 2006 | 09:33 AM
it may spool faster, but do you honestly want all that reversion from a poorly designed manifold going back into your cylinders
i'd rather save the extra couple hundred and get a good manifold (i.e Peakboost FTW $599)
Old Sep 27, 2006 | 09:44 AM
raene's Avatar
Sometimes $300 is the difference between having enough money to race and having enough money to eat. If I remember right, my log cost $200.
I'm on a log manifold too, hopefully I'll scrape together enough to change it out sometime. Maybe next 2007 winter.
Old Sep 27, 2006 | 10:11 AM
PM-Performance's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowbunny &raquo;</TD></TR><TR><TD CLASS="quote">i have a lsvtec and was wondering if a log manifold is capable of 300-350whp??
thanks</TD></TR></TABLE>
are you serious?
Old Sep 27, 2006 | 10:44 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: log manifold capable of 300whp?? (PM-Performance)
made 330 with a slipping clutch and a un-modified drag kit.
hell the inline pro guys are using their stainless log and goin 9's with it?
Old Sep 27, 2006 | 01:07 PM
Squirtle's Avatar
362hp on line pro manifold with b18b here.
Old Sep 27, 2006 | 03:15 PM
95GSRTT
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PM-Performance &raquo;</TD></TR><TR><TD CLASS="quote">
are you serious?</TD></TR></TABLE>
no **** right? where do these questions ******* come from?
Old Sep 27, 2006 | 03:56 PM
ringgold's Avatar
Default Re: log manifold capable of 300whp?? (95GSRTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">made 330 with a slipping clutch and a un-modified drag kit.
hell the inline pro guys are using their stainless log and goin 9's with it?</TD></TR></TABLE>
Same here, making over 300whp with a drag mani and turbo on 10psi. Cant compain at all
Old Sep 27, 2006 | 04:33 PM
no i was just bord and made it up..yea im serioues..this is honda tech is it not?..this is y people like me come here to ask questions so people that have knolege can give anwsers...not to get dumb remarks from a smart *** like u
Old Sep 27, 2006 | 05:45 PM
95GSRTT
Guest
Posts: n/a
spell check is your friend, and you can search just a future fyi. Im sure you would have only found like 400 threads for this topic.
Old Sep 27, 2006 | 06:59 PM
ATYPR's Avatar
I'm running a drag manifold now.
398whp on 93 octane with a b16
Old Sep 28, 2006 | 05:02 AM
paulzy's Avatar
Kenny tran used to run the Revhard manifold in his civic back when 9's were hotshit for Hot Rod cars.
Old Sep 28, 2006 | 05:54 AM
pbsracerx's Avatar
Default Re: (paul vang)
First turbo set-up was a maxrev log manifold and a T3/TO4E .57 trim and I made 401 at 18psi.
Can be done!
Joshua
SlowMotion Motorsports
Old Sep 28, 2006 | 06:03 AM
ringgold's Avatar
Default Re: (pbsracerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pbsracerx &raquo;</TD></TR><TR><TD CLASS="quote">First turbo set-up was a maxrev log manifold and a T3/TO4E .57 trim and I made 401 at 18psi.
Can be done!
Joshua
SlowMotion Motorsports</TD></TR></TABLE>
Im running the same turbo (I think ) Anyways I could easily make 400whp on a log mani
FormulaGSR
Apr 5, 2005 08:09 PM
usdmcivic94
Jan 22, 2005 12:45 PM
nebulight
Nov 13, 2004 01:44 PM
the.hamburglar
Feb 2, 2004 07:29 PM
yimmy
Jan 12, 2004 08:32 AM
