Need sum info on this setup
Old Sep 29, 2006 | 10:57 AM
bstdlsteg69's Avatar
Default Need personal opinion on this setup
I have a B18a1. The guy building my motor is putting eagle rods from a gsr, and a micropolished gsr crank in it, as well as 8.8to1 compression wiseco forged pistons, and boring it .20 over making it 81.5 mm. I was just wondering if having the gsr rods and crank will make any difference in power, or revving or anything.
Extra info
POrt and polished ls head
tubular turbo manifold
63 ar turbo
stock ls intake
Old Sep 29, 2006 | 11:00 AM
Schister66's Avatar
Man U FTW
get aftermarket rods while its apart....the crank doesn't matter unless you're going crazy hp
Old Sep 29, 2006 | 11:01 AM
Default Re: (Schister66)
u might of misread, or i might of used bad choice of words. They are aftermarket eagle h beams, they are just for the gsr.
Old Sep 29, 2006 | 11:04 AM
Schister66's Avatar
Man U FTW
yeah i misread that one....lol
Old Sep 29, 2006 | 11:06 AM
woudl u mind me askin what you have done to your gsr, im trying to hit 300hp wit a decent amount of torque.
Old Sep 29, 2006 | 11:09 AM
Schister66's Avatar
Man U FTW
T3/T04E 60 trim .63ar
SPoolin AC compatible log
2.5" DP and exhaust (no cat)
2.5" charge piping
31x6x3" FMIC
RC550 injectors
Tial 50mm BOV
Tial 38mm WG
chipped P28 on Crome
tuned on 9psi on the stock GSR engine....i regret not boosting 12psi when i got tuned
Old Sep 29, 2006 | 11:17 AM
Curturbo's Avatar
Default Re: Need personal opinion on this setup (bstdlsteg69)
what happened to the gsr motor that the rods and crank are from? imo... the gsr block would be a better choice due to the fact it has a girdle from the factory. Even better if you have a ls crank and aftermarket ls rods in it. (real ls/vtec)
But if you only have the ls block than the gsr rods and crank should be just fine for revving. What do you plan on revving it to? I would recomend getting arp mains if you could and you could handle 8-9k just fine.
-Curt
Old Sep 29, 2006 | 08:30 PM
Default Re: Need personal opinion on this setup (RingOfire)
i have no clue were the gsr motor the crank came out of is, yes ur right, i would of loved to had the true lsvtec setup. All i have is an ls block wit eagle hbeams for the gsr and wiseco turbo pistons. im using a cometic head gasket and all honda oem gaskets, the motor will be bored .20 over.
i understand that i could revv 8-9 wit the arp mains, but what about the stock ls valvesprings, would i experience float, im scared for the spring to pop, thats what killed my last motor, spring popped, brand new type r pistonns slammed into the valve, cracked the block etc
Old Sep 30, 2006 | 06:45 AM
Curturbo's Avatar
whoa whoa whoa.... my bad... i guess i misunderstood the fact that you are running an ls head. I wouldn't try taking that past 7500 without upgrading your springs and retainers.
Old Sep 30, 2006 | 06:55 AM
Turbo-LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bstdlsteg69 &raquo;</TD></TR><TR><TD CLASS="quote">i have no clue were the gsr motor the crank came out of is, yes ur right, i would of loved to had the true lsvtec setup. All i have is an ls block wit eagle hbeams for the gsr and wiseco turbo pistons. im using a cometic head gasket and all honda oem gaskets, the motor will be bored .20 over.
i understand that i could revv 8-9 wit the arp mains, but what about the stock ls valvesprings, would i experience float, im scared for the spring to pop, thats what killed my last motor, spring popped, brand new type r pistonns slammed into the valve, cracked the block etc</TD></TR></TABLE>
I wouldnt go past 7200 with boost, 7500 you can get valve float, stock LS springs are super weak. Just pick up a set of duals/retainers, there really not all that much and cheap to have installed if you cant do it your self. I run crower duals and rev my ls to 8500 all the time, plan on going higher just having ignition issues at the moment
Leric
11
Aug 9, 2013 06:45 PM
electronem1
Jul 27, 2009 06:12 AM
NaIsGay
Jun 22, 2009 07:48 PM
TurboEH2
Apr 2, 2005 11:03 AM
advanracing62
Oct 11, 2003 09:57 PM
