Where to tap for water temp sensor?
Old Sep 26, 2006 | 04:17 PM
vtec.dc2's Avatar
Default Where to tap for water temp sensor?
i was thinking to drill into drain bolt in front of the block. another way is to t into stock location.. but what about tapping somewhere along hoses?
Old Sep 26, 2006 | 04:28 PM
inspyral's Avatar
Mine is tapped into the upper radiator hose with a GReddy adapter. It's the blue thing in this pic:
I think it's either the 32 or 34mm one.
Old Sep 27, 2006 | 11:54 AM
vtec.dc2's Avatar
Default Re: (inspyral)
sounds like a good idea, but i don't want to spend 40-50 on something like that.. what else can i use in between radiator hose to accomplish same result.
Old Sep 27, 2006 | 12:02 PM
TURBODC4TEG's Avatar
Default Re: (vtec.dc2)
honestly i guess those are your best bets
Old Sep 27, 2006 | 12:04 PM
mike1114's Avatar
Default Re: (TURBODC4TEG)
Its ghetto but you could braze/weld a fitting to a piece of pipe, and use that like the greddy adapter pictured in blue.
I personally like the idea of finding a fitting to go where the drain bolt is in the front.
Old Sep 27, 2006 | 12:10 PM
RCautoworks's Avatar
Default Re: (mike1114)
What I did
Old Sep 27, 2006 | 12:44 PM
BoostedEG6's Avatar
Default Re: (90blackcrx)
what sensor is it? I know that the sensor that comes with the Defi gauge will go into the stock location, that is where I have mine at and works fine
Old Sep 27, 2006 | 07:52 PM
Muckman's Avatar
Moderator in Chief
Default Re: Where to tap for water temp sensor? (vtec.dc2)
Put it in the front water neck on the head. On older B series there was a bleeder valve there. On newer ones its not tapped but partially drilled. Retapp it and its in a perfect location.
Old Sep 28, 2006 | 05:38 AM
vtec.dc2's Avatar
Default Re: Where to tap for water temp sensor? (Muckman)
wihtout searching through helms.. where/what exactly is a water neck?
Old Sep 28, 2006 | 05:56 AM
mike1114's Avatar
Where the bleeder valve is on the head on the front of the block.
Also where the top rad hose clamps onto the head.
Boost16
Mar 11, 2015 12:29 AM
punkracer
Jul 4, 2010 06:55 AM
type Gendy
Sep 7, 2009 01:07 PM
yellowturbo
Jun 29, 2005 05:40 AM
Dunc
Mar 19, 2005 10:45 PM
