another msd ignition problem ?@@ help
Old Oct 1, 2006 | 11:24 AM
THEDirtyDseriesWOOT's Avatar
Default another msd ignition problem ?@@ help
ok i searched and read everyone says it breaks up on them up top... well mine ran good for about 5 mins purred it was sweet.. then after i got the idle to a good afr.. i went to street tune it started spuddering and crap i get back it spudders all though the rpms even at idle ?? what the ehll i wrong i need to get it ready for a tune on the 6th would moving my ground be good enough??? i have msd 6al blaster 2 coil and msd cap and rotor
Old Oct 2, 2006 | 01:58 PM
Default Re: another msd ignition problem ?@@ help (hitatree.at125mph)
ttt
Old Oct 2, 2006 | 02:49 PM
1boostedcivic's Avatar
have u tried closing the gap to .28?
Old Oct 2, 2006 | 03:23 PM
JSPECSIR's Avatar
Default Re: another msd ignition problem ?@@ help (1boostedcivic)
are you sure the plugs arent fouled/
Old Oct 2, 2006 | 03:56 PM
beepy's Avatar
Capacitive discharge ignitions just don't seem to work well with turbos. I also had problems with mine and it is a mild turbo system.
You probably had misfires on the first run and wetted the plugs. Remove the plugs, clean them, and ensure the gap is in the 0.028-0.032 range. Then sell the 6al on Ebay and go back to the OEM ignition system.
Old Oct 2, 2006 | 04:06 PM
93turbo16's Avatar
Default Re: another msd ignition problem ?@@ help (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">
You probably had misfires on the first run and wetted the plugs. Remove the plugs, clean them, and ensure the gap is in the 0.028-0.032 range. Then sell the 6al on Ebay and go back to the OEM ignition system.</TD></TR></TABLE>
X2
Old Oct 2, 2006 | 04:52 PM
JSPECSIR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Capacitive discharge ignitions just don't seem to work well with turbos. I also had problems with mine and it is a mild turbo system.</TD></TR></TABLE>
why? please explain.
also, this shows it good up to 15,000rpm.
http://www.msdignition.com/ignition_6_6420.htm
lude98SH
Nov 3, 2005 08:15 PM
blaze the chemi
Oct 28, 2005 05:02 AM
lude98SH
Sep 15, 2005 08:35 AM
IloveNewt
Apr 23, 2004 02:26 PM
loki2323
Jun 17, 2002 07:08 AM
