piston rings
Old Sep 30, 2006 | 01:34 PM
turboant's Avatar
Default piston rings
i need to know where to set the piston ring gaps so i can put the pistons back in the block on my rebuild... a picture or anything will really help... or an old post that someon can link me too...thanks! oh its for a b18a motor thanks again
Modified by turboant at 12:35 AM 10/1/2006
Old Sep 30, 2006 | 01:40 PM
adseguy's Avatar
Default Re: piston rings (turboant)
I followed this from Jeff Evan's site: "The formula for sizing the top and bottom compression rings is bore size (in inches) x 0.006", and then add 0.004 for the secondary compression ring gap"
Old Sep 30, 2006 | 03:32 PM
gsrt nick's Avatar
Default Re: piston rings (adseguy)
in je,srp,ross and cp directions it says the 2nd ring should be larger then the 1st or it will cause static pressure that the ring cant bleed off.
in je's it say.oo5 x bore for street and .0055x bore fore moderate boost and .006 for race. for second ring add .0005 to formulas for the 1st ring
good luck
Old Sep 30, 2006 | 03:52 PM
turboant's Avatar
Default Re: piston rings (gsrt nick)
ok thank how i need to know where to place the piston ring.
Old Sep 30, 2006 | 03:56 PM
Muckman's Avatar
Moderator in Chief
Oem gap positioning.
JJDub
Engine Machining & Assembly
May 31, 2017 07:30 AM
tobster
Jan 22, 2010 05:10 PM
EJ8chu
Jun 16, 2008 05:26 PM
2 0 3
May 6, 2006 04:23 PM
ericrx_88
Jun 1, 2005 11:34 PM
