Manual Boost Controller Install Problem - overboost problem
Old Sep 27, 2006 | 08:14 AM
xrdriver's Avatar
Default Manual Boost Controller Install Problem - overboost problem
I installed a TurboSmart Dual Stage MBC last night but I am not happy with it. I am only trying to use the low boost setting at this time.
I hooked the tee into the line coming from the turbo to the side port on my TiAL 40mm wastegate. The arrow points towards the wastegate. I have a .5 bar wastegate spring and prior to the MBC I ran a solid 7psi ALL the time.
With the controller dial turned all the way to minimum I get 10psi from about 4000rpm up to my vtec crossover at 4900rpm. The boost then falls to a solid 7psi to redline. If I turn the dial I get 12psi until vtec then it drops to 8psi to redline.
I am running a gt30r with a full-race manifold on a stock gsr engine.
What is going on? What am I doing wrong?
Old Sep 27, 2006 | 10:00 AM
yellowturbo's Avatar
I run a Turbo XS DSBC but I think that the Turbosmart is the same thing or almost.... well I just installed the boost controler like 2 weeks ago but I will adjust it tonight. I hope it will work.
I blocked the line that was coming from the turbo to the wastegate ( I was running a EBC ). Now the side port of the wastegate is hooked to the bottom of the b.c. and the side of the b.c is hooked to the manifold to get boost pressure.
OR maybe your not adjusting the good screw... look at one of my old topic https://honda-tech.com/zerothread?id=1753040
mmh finally the two boost controler are not the same at all... here is the instruction. You cant really go wrong http://www.turbosmart.com.au/index.php?id=43
Old Sep 28, 2006 | 08:44 AM
xrdriver's Avatar
Default Re: (yellowturbo)
I hooked up a regular bleeder valve type BC (HKS VBC) and it works perfectly.
My problem has to be associated with the TurboSmart controller restricting boost to the wastegate to help spool. Is there any specific size or length of vacuum hose I should be using?
Old Sep 29, 2006 | 10:09 AM
xrdriver's Avatar
Default Re: (xrdriver)
anyone?
Old Sep 30, 2006 | 03:45 PM
xrdriver's Avatar
bump
Old Oct 2, 2006 | 05:53 AM
xrdriver's Avatar
bump....will it work better on a higher spring?
Old Oct 4, 2006 | 02:14 PM
xrdriver's Avatar
hello?
Old Oct 8, 2006 | 09:41 AM
xrdriver's Avatar
Am I the only person to ever have a problem with these things? Turbosmart won't respond to my inquiry either lol.
Gunner142
Feb 9, 2009 04:39 PM
riceball777
Feb 13, 2006 04:52 AM
94lsboost
Jan 6, 2005 05:58 PM
Wo-Nelly
Feb 23, 2004 01:28 PM
