SOHC turbo DYNO question?
what gear on a MUSTANG DYNO do you gain max HP/TQ.......................is it 3rd or 4th do you make your peak HP
Re: SOHC turbo DYNO question? (kamakaze1)
well,this is the situation,i made 184hp/160tq @7200 in 4th.psi was at 8lbs.w/11.4 a/f ratios all the way through the powerband.question is do i make 3rd gear passes at 7500rpm...............................i should be well over 200hp
92 civic VX B18c
04-20-2004 02:23 AM
