any required reading before I consider Nitrous?
Old Oct 1, 2006 | 04:10 PM
andylawcc's Avatar
Default any required reading before I consider Nitrous?
i searched a few post and got some basic information. (like what is dry, wet single port, multi port). I still don't have a picture of how they really work but I got the general idea. (Dry is cheaper and easier to install, but doesn't yield as much as power as a wet one would)
Anyways, before I get any further, my objective is to increase horsepower without significant, major modifications. I am not looking at anything above 50 shots anyways. The reason I want to go with nitrous is, and correct me if I am wrong, this is the cheapest way to boast hp compare to engine swap, turbo, or S/C. I am driving a stock 99 LX. Can the D-series handle a Dry system without changing the injectors, fuel pump, and/or others parts?
Old Oct 1, 2006 | 04:15 PM
kraig8's Avatar
you want to go with a wet kit. that way you dont have to relie on your stock fuel system to add the extra fuel. just make sure you jet it right and your good to go. most people that buy dry kits end up upgrading to wet kits.
Old Oct 1, 2006 | 04:26 PM
andylawcc's Avatar
Default Re: (kraig8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kraig8 &raquo;</TD></TR><TR><TD CLASS="quote">you want to go with a wet kit. that way you dont have to relie on your stock fuel system to add the extra fuel. just make sure you jet it right and your good to go. most people that buy dry kits end up upgrading to wet kits. </TD></TR></TABLE>
let's say if I am going to sell the car, can I remove the wet kit while leaving the stock engine bay RELATIVELY intact?
Old Oct 1, 2006 | 04:28 PM
kraig8's Avatar
yes. the only way to tell is that you will have a hole in your intake pipe.
Old Oct 1, 2006 | 04:43 PM
andylawcc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kraig8 &raquo;</TD></TR><TR><TD CLASS="quote">yes. the only way to tell is that you will have a hole in your intake pipe.</TD></TR></TABLE>
thank you.
and i suppose this
http://us.st11.yimg.com/us.st....60615 is a Dry system right? (from http://www.titanmotorsports.com/niexma.html)
anyways, from the HondaMarketplace it looks like the price for a used Dry or used Wet is somewhat in the same ballpark (350-450). That looks like a good price no?
Old Oct 1, 2006 | 08:18 PM
Top Ramen's Avatar
Default Re: (andylawcc)
Find some knowledgeable domestic drag guys in your area. No one is better at using nitrous. They can talk you through the different styles of nitrous injection, the pros and cons of the various manufacturers, progressive controllers, dual stage kits, how to tune by reading plugs, etc.
They will obviously give you some crap about your import, but it is well worth what you can learn from them.
Good luck with your project.
Sr420Det
Feb 29, 2008 08:09 PM
invisible
Sep 11, 2007 03:53 AM
dubman410
Jan 4, 2005 02:59 PM
thehondaguru
Oct 17, 2002 11:39 PM
