oil line setup questions
Old Sep 26, 2006 | 08:41 AM
Cisco93Lude's Avatar
Default oil line setup questions
I am going to turbo my H23 lude with a big 16g that im buying of someone. it is in good condition and eveything with no play at all. I was just wondering about the oil line(s). I heard something about needing a restrictor or something b/c preludes have 100psi+ of oil pressure. Is this true?? also how did you guys tap your oil feed line? did you go from the oil sensor thing or did you get an oil filter block adapter? I am looking into the easiest and cheapest way. Is the oil sensor tapping hard to get at or hard to do?? does anyone have pics or have sites where they got their oil stuff. Thanks.
Old Sep 28, 2006 | 06:37 PM
90 JDM EF8's Avatar
Default Re: oil line setup questions (Cisco93Lude)
get the oil block fitting from stealthmodeperformance.com for $20...it makes it really easy and clean and your oil pressure sensor goes on the end of it and then there is 2 ports on the sides for turbo feed line and oil pressure guage or whatever you want
balbowskie
Feb 17, 2012 06:47 PM
x92preludesix
Mar 21, 2007 12:35 PM
Cisco93Lude
Sep 27, 2006 03:26 AM
Racerage1
Apr 11, 2003 11:01 PM
slingshotsi
Sep 9, 2001 06:11 PM
