Blue Smoke
Old Sep 28, 2006 | 12:12 AM
jdmcivicb16a2sc61's Avatar
Default Blue Smoke
My girlfriend said she sees blue smoke when i get on it, is this something serious?
Old Sep 28, 2006 | 12:16 AM
lakai_19's Avatar
your piston rings are going out most likly
Old Sep 28, 2006 | 01:03 PM
Default Re: (lakai_19)
thats all?
Old Sep 28, 2006 | 10:13 PM
Turbo_y8's Avatar
Default Re: (jdmcivicb16a2sc61)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicb16a2sc61 &raquo;</TD></TR><TR><TD CLASS="quote">thats all?</TD></TR></TABLE>
lol
Old Sep 28, 2006 | 10:32 PM
rebo0t's Avatar
get a can of that Engine Restore stuff... lol
jokes aside, most likely your rings are going. do a compression/leak down test.
Old Sep 29, 2006 | 12:27 AM
jep's Avatar
jep
it could be valve seals also.....i think it depends on when u see the smoke. I wish I knew more. can someone else shed some light. thanks.
Old Sep 29, 2006 | 02:10 AM
K SERIES's Avatar
Default Re: (jep)
make a vid and upload it then put link here.then well tell you exactly whats wrong with it.
Old Sep 29, 2006 | 03:53 AM
QuickDxEk's Avatar
I was wondering about this too. My car smokes around vtec-6000 grand. Its more of a gray color than full on blue. My lastest comp test was 220 across the board!!
Old Sep 29, 2006 | 10:00 AM
Turbo_y8's Avatar
Default Re: (QuickDxEk)
blue smoke could also be turbo seal related.
Old Sep 29, 2006 | 10:57 AM
Schister66's Avatar
Man U FTW
it is not valve seals
smoke on acceleration means rings
smoke on deceleration means valve seals
Old Sep 29, 2006 | 11:30 AM
Turbo_y8's Avatar
Default Re: (Schister66)
try using a thicker weight oil. Could help slightly also.
Old Sep 29, 2006 | 11:38 AM
SOHC_MShue's Avatar
Default Re: Blue Smoke (jdmcivicb16a2sc61)
do a compression and leakdown. If they come out fine then its most likely turbo seals. Hows your return line look?
Old Sep 29, 2006 | 01:39 PM
vxhatched's Avatar
On acceleration (piston rings) on deacceleration it (valve seals), cause you are creating a vacuum.
Old Oct 4, 2006 | 12:18 PM
QuickDxEk's Avatar
Why would rings just blow/leak above Vtec?? Someone said during acceleration it would be rings. If i stay below vtec it doesnt smoke at all. Due to the higher oil pressure, dont most Vtec cars smoke a little??
Old Oct 4, 2006 | 07:27 PM
Turbo_y8's Avatar
if its your rings. Go start your car, within a minute the exhaust should get smokey. Open your hood toss a beather filte ron your crank case vent and that should just be smoking like nuts. If the following it happing, you dont have **** rings. Could be turbo seal or just another typical get in to VTAKKKK smoking machine.
Old Oct 4, 2006 | 09:00 PM
Blackack26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">it is not valve seals
Not nessasarly.. I was blowing alot of blue smoke, hard acceleration, engine braking, and after idling for a while. Replaced the valve seals, and now it is perfect, no blue smoke what so ever. I think the oil can build up, and then burn off when the egt gets to a higher temp(in boost for example).
Old Oct 4, 2006 | 11:49 PM
john d ftw
Guest
Posts: n/a
Default Re: (moops vs moors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moops vs moors &raquo;</TD></TR><TR><TD CLASS="quote">yeah just change your rings the next time you get gas.</TD></TR></TABLE>
haha or next time you wash it is a good time as well
Old Oct 5, 2006 | 05:17 AM
QuickDxEk's Avatar
Default Re: (Turbo_y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_y8 &raquo;</TD></TR><TR><TD CLASS="quote">if its your rings. Go start your car, within a minute the exhaust should get smokey. Open your hood toss a beather filte ron your crank case vent and that should just be smoking like nuts. If the following it happing, you dont have **** rings. Could be turbo seal or just another typical get in to VTAKKKK smoking machine.</TD></TR></TABLE>
My, car doesnt have any blow by at all. The compression is at 220 across the board. I always knew vtec smoke but there is some many people saying diffrent things, I want to know for sure!!
sde780
23
Feb 19, 2013 05:02 AM
LaOXXKIDD
Aug 15, 2009 12:05 PM
KevinSmith88
Feb 23, 2009 04:20 PM
GSRfromdaBAY
Jan 23, 2008 08:46 PM
blub18
Mar 27, 2006 09:48 PM
