What else do I need for 550+hp?
Old Sep 25, 2006 | 06:44 PM
nitroice40's Avatar
Default What else do I need for 550+hp?
Trying to make 550+hp. Any advice from the VETERANS would help. This is all stuff I already have, I am putting this together in the next week and need some input.
B16 block with eagle crank 89mm stroke and 84mm bore
Je pistons
eagle rods
arp main studs
aebs head studs
new oil pump
B16a2 head
stock IM b16
stock B16 cams (I have a mistery set,I was told they were skunkstg2 but notsure)
crower springs/retainers
Greddy timing belt
skunk2 cam gears
Rc1000cc
walbro 255hv
GE fuel rail
aem fpr
Turbonetics 62-1 stg5 wheel
tubular manifold T4
35mm tial
3"Dp and Exhaust (no cat with a apexi N1)
Msd 6BTM (I dont use the btm)
Blaster2 coil
GM 3 bar
Crome Pro
2.5 IC pipe
big intercooler
stock TB or 68mm
Action 6 puck sprung
alu flywheel
OBX LSD
I am thinking about a revhard manifold and a GE block girdle. And some 3" ic pipe
What do you guys think? Anything I should change or get?
The cams I have are unknown there are part numbers on the ends but I can find out what they are.
Modified by nitroice40 at 11:10 PM 9/25/2006
Modified by nitroice40 at 11:11 PM 9/25/2006
Modified by nitroice40 at 11:25 PM 9/25/2006
Modified by nitroice40 at 11:26 PM 9/25/2006
Modified by nitroice40 at 11:35 PM 9/25/2006
Modified by nitroice40 at 7:44 AM 9/26/2006
Old Sep 25, 2006 | 06:54 PM
siblues's Avatar
Default Re: What else do I need for 550+hp? (nitroice40)
I have almost the same exact setup just different parts and i pulled 483 at 18 psi.
Old Sep 25, 2006 | 06:59 PM
spooncivic1's Avatar
which clutch?
Old Sep 25, 2006 | 07:00 PM
nitroice40's Avatar
Default Re: (spooncivic1)
I have an alu flywheel and a action 6 puck sprung clutch
Old Sep 25, 2006 | 07:04 PM
namm's Avatar
(1) Find out what type of cams you have, if they are N/A cams you might have problems tuning
(2) You did not mention what type of rods you have, if you have a 89mm crank in a B16A Block you obviously want custom short rods. Whatever the case you know you need rods
(3) What type of management are running AEM, Hondata, Crome. They all can get the job done. The tuner is the key
Old Sep 25, 2006 | 07:12 PM
nitroice40's Avatar
Default Re: What else do I need for 550+hp? (namm)
I have posted pics up here before and nobody knows what cams they are. I have eagle rods. I am going to b using crome pro
Old Sep 25, 2006 | 07:18 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
maybe a better intake manifold, at least a skunk2/blox
Old Sep 25, 2006 | 08:12 PM
PrecisionH23a's Avatar
Default Re: (tannerLSt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt &raquo;</TD></TR><TR><TD CLASS="quote">maybe a better intake manifold, at least a skunk2/blox</TD></TR></TABLE>
Ditto.
Old Sep 26, 2006 | 03:26 AM
nitroice40's Avatar
Default Re: (PrecisionH23a)
What do you guys think about the IC piping being 2.5 and no block guard?
Old Sep 26, 2006 | 03:29 AM
g2turbo's Avatar
Default Re: (nitroice40)
I woulndt worry about the intercooler piping at all. As for the blockguard you will get mixed opinions... It is not neccessary to run one.
Old Sep 26, 2006 | 03:43 AM
nitroice40's Avatar
Default Re: (g2turbo)
I meant block girdle, Iam sorry. Its a sleeved block
Old Sep 26, 2006 | 04:59 AM
Jay_Sensing's Avatar
2.5 inch intercooler piping is fine, going to three isn't needed and only picks up a few CFM and looses a lot in velocity plus creates a bit more lag.
The stock IM is a weak spot though, I would personally go with a Victor X but even an AEBS would be better. Stock is just really restrictive.
Also, look into some GSR cams, in a setup that size, they are going to help a good bit. I wouldn't mess with skunk 2 stg 2 cams in a turbo setup but that's just me.
Wastegate is a bit on the small side for that turbo and you may end up with boost creep in the higher gears as well.
Old Sep 26, 2006 | 08:11 AM
purpleh22's Avatar
Default Re: (Jay_Sensing)
New water pump and an electronic boost controller, if it's going to see much street time. You won't be able to use that much power on the street very well.
Old Sep 26, 2006 | 10:01 AM
nitroice40's Avatar
Default Re: (purpleh22)
thanks for the good info. The car's going to be used mostly on the track.
Any other feedback??
Old Sep 26, 2006 | 10:22 AM
beaneg6's Avatar
gsr cams 60$ just throwing it out there but it does look like a good setup. just pick your tuner carefully!
Old Sep 26, 2006 | 04:23 PM
nitroice40's Avatar
Default Re: (beaneg6)
do you think i will need bigger cams thanb gsrs?
Old Sep 26, 2006 | 07:11 PM
nitroice40's Avatar
Old Sep 26, 2006 | 07:23 PM
Speed Infliction's Avatar
ctr/itr cams FTW!
Old Sep 26, 2006 | 07:28 PM
nitroice40's Avatar
Default Re: What else do I need for 550+hp? (Speed Infliction)
I have seen alot of people hit some nice numbers on stg2s.
Old Sep 26, 2006 | 07:29 PM
swapped95's Avatar
where can you find crome?
Old Sep 26, 2006 | 07:45 PM
nitroice40's Avatar
Default Re: (swapped95)
on my rimz.............
Old Sep 26, 2006 | 07:52 PM
swapped95's Avatar
you dont say? if you didnt understand what i was asking...ill clairify...crome pro, neptune, uberdata...etc. where would one go about finding one??????? just asking...
Old Sep 26, 2006 | 07:54 PM
nitroice40's Avatar
http://www.pgmfi.org/twiki/bin...Tools
You have to pay for crome pro
Old Sep 26, 2006 | 07:56 PM
nitroice40's Avatar
I was going to say the search button, but I won't f with ya.
Old Sep 26, 2006 | 08:00 PM
swapped95's Avatar
i couldnt get search to work for me thats why i asked...ive seen how everyone gets ragged on for not using search but i at least tried it first...
