white smoke when in boost. compression consistent
Old Sep 29, 2006 | 04:34 PM
ragethemachine86's Avatar
Default white smoke when in boost. compression consistent
I thought i had blown my headgasket after white smoke started shooting out of my exhaust while gunning it. Did a compression test today and it was 175 across all 4 cylinders on a cold engine.
The 3 things that could explain the white smoke are headgasket, bad rings or blown turbo seals. I feel like i can eliminate the first 2 due to the compression test and conclude that the smoke is coming from the turbo. Any objections?
Thanks ahead of time for any input.
-Johnny.
Old Sep 30, 2006 | 07:03 AM
Default Re: white smoke when in boost. compression consistent (ragethemachine86)
bump
Old Sep 30, 2006 | 07:58 AM
Snafubmx234's Avatar
Let me guess - Stock head bolts?
Old Sep 30, 2006 | 10:40 AM
boosted-EG6's Avatar
Default Re: (Snafubmx234)
its the head gasket if you are getting white smoke! if you dont have head studs you should really think about getting some and use a really good tourqe wrench (snap-on, craftsmen) heat soke them then re-tourqe for maximun seal
Old Sep 30, 2006 | 01:03 PM
Default Re: (boosted-EG6)
arp headstuds + new headgasket = fix?
Old Sep 30, 2006 | 02:54 PM
Semnos's Avatar
COuld be that you're running lean....running too lean also gives out a white smoke sometimes if it didn't blow up though
Old Sep 30, 2006 | 02:57 PM
Default Re: (Semnos)
It is a possibility that I am running lean, however I havent changed my tune in several months. This happened about a week ago.
Old Sep 30, 2006 | 03:41 PM
Jay_Sensing's Avatar
Sounds like head lift to me man. You can have perfect compression across the board and still have it because it will only leak under boost.
Old Sep 30, 2006 | 04:15 PM
SOHC_MShue's Avatar
I am seriously doubting the head lift. Probably a turbo seal issue. People always say they are seeing white smoke, but half the time burning oil smoke looks very white. It will have a bluish tint, but can be hard to see.
Old Oct 1, 2006 | 08:22 PM
Top Ramen's Avatar
Default Re: white smoke when in boost. compression consistent (SOHC_MShue)
test your coolant. There are kits that will tell you if you are getting exhaust gases in there.
Old Oct 1, 2006 | 10:52 PM
Phoenix1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">I am seriously doubting the head lift. Probably a turbo seal issue. People always say they are seeing white smoke, but half the time burning oil smoke looks very white. It will have a bluish tint, but can be hard to see.</TD></TR></TABLE>
I agree. Perform a lead-down test to find the cause.
Old Oct 1, 2006 | 11:16 PM
turbotime's Avatar
how much hp are you making? on how much psi?
Old Oct 2, 2006 | 02:13 AM
Hybrid96EK's Avatar
Default Re: white smoke when in boost. compression consistent (Phoenix1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phoenix1 &raquo;</TD></TR><TR><TD CLASS="quote">
I agree. Perform a lead-down test to find the cause.</TD></TR></TABLE>
Compression is consistant.. Only smokes in boost. Leak down test isn't going to show crap. Now a block tester on the other hand will verify if its the headgasket or not.
Old Oct 3, 2006 | 09:33 AM
Default Re: white smoke when in boost. compression consistent (Hybrid93Eg)
did another compression test yesterday but with fully warmed up motor this time. 195-190-190-185.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">how much hp are you making? on how much psi?</TD></TR></TABLE>
this happened a week b4 i was getting it tuned. been running a friends tune with same exact car/setup as mine temporarily. so no dyno numbers. 7psi
btw i produced some smoke for a friend last night and he said it definitely smelled like oil and not coolant, he could always be wrong but ill assume he knows how to distinguish.
chu77
May 25, 2006 07:55 AM
bukbukintegra
May 17, 2005 04:45 PM
jdmtim
Nov 20, 2003 01:43 PM
SIK IN DA HED
Mar 23, 2003 02:09 PM
Randomlude
Oct 12, 2002 03:56 PM
