THE MISSING LINK to get hondas to read boost how do i make one
Old Sep 30, 2006 | 09:15 PM
civic nation's Avatar
Default THE MISSING LINK to get hondas to read boost how do i make one
ive been boosting wthout but my vafc is always on plus ++
Old Sep 30, 2006 | 09:18 PM
D@nnY's Avatar
Default Re: THE MISSING LINK to get hondas to read boost how do i make one (civic nation)
do some research..the stock map sensor reads 11psi... and a missing link doesnt make it read boost ...it does the opposite..we dont use those here..at least n9ot for the last 4 years
Old Sep 30, 2006 | 09:24 PM
SOHC_MShue's Avatar
its simple...you dont use one
oh because thats what a friend told me he said that i needed it because my car wasnt reading boost on my apex vafc i didnt want to argue with the guy because he builds car for a living
Old Sep 30, 2006 | 09:45 PM
SOHC_MShue's Avatar
Default Re: (civic nation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic nation &raquo;</TD></TR><TR><TD CLASS="quote">oh because thats what a friend told me he said that i needed it because my car wasnt reading boost on my apex vafc i didnt want to argue with the guy because he builds car for a living</TD></TR></TABLE>
damn you shouldn't ever let that guy build your car. The missing link keeps your map sensor from seeing boost.
Old Sep 30, 2006 | 09:53 PM
no my cars already boosted damn that dude was probably just trying to get me to buy one i just thought he knew what he was talking about because he has a fully builtf23 vtec turbo on 25 psi in a 98 sedan
Old Sep 30, 2006 | 10:42 PM
preludedriva's Avatar
i thought missing links trick the ecu in reading boost
so theres no point in one ? damnit i just made one lol
i heard 3 bar is needed?
mtber's Avatar
Do your self a favor, read http://phearable.net/tech/efibeginnerguide.html
Old Sep 30, 2006 | 11:27 PM
i have a p28 chipped w uberdata for boost he said i needed it to accomodate it i guess
Old Oct 1, 2006 | 11:36 AM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic nation &raquo;</TD></TR><TR><TD CLASS="quote">i have a p28 chipped w uberdata for boost he said i needed it to accomodate it i guess </TD></TR></TABLE>
no if you use a missing link with that your engine will not like it so much. Basically the ecu wont see that you are boosting and therefore not compensate with more fuel and pull timing.
Old Oct 1, 2006 | 07:40 PM
D@nnY's Avatar
Default Re: (SOHC_MShue)
imagine a check valve that only flows air one way....if you suck through it air will flow. if you blow through it it will shut...it allows the sensor to read vaccuum and run the motor correctly partial throttle and not let any pressure get to the sensor under boost so the ecu doesnt freak out. if the ecu is chipped you can set up the program to read up to 11 psi off the stock map sensor. and ditch the afc
abmerop18
Jun 2, 2006 05:35 PM
MickeeFREE
Apr 14, 2005 09:36 PM
elpiar
Mar 22, 2005 06:02 PM
illestrolla247
Aug 2, 2004 09:06 AM
Griffin@Camtech
Mar 19, 2004 01:16 PM
