type r tranny ???'s
Old Sep 30, 2006 | 03:46 PM
spoolin_teg's Avatar
Default type r tranny ???'s
I currently bought a 2001 type r tranny. I got a good deal from a friend on it, but I dont think the LSD is working...But he says its not gonna burn both tires off the line, its more for track driving. I think he is just covering up so I dont get mad. Does anyone else have this tranny and burn BOTH tires? : x
I put the GM LSD additive as well. Is this stock LSD good enough? I mean even when I shift into second, just the one wheel spins.....help
Old Sep 30, 2006 | 04:04 PM
umop-apisdn's Avatar
Default Re: type r tranny ???'s (spoolin_teg)
To see if your diff is working, or even present, in your case.
1. Set the parking brake and block the rear wheels.
2. Raise the front wheels off the ground (use jackstands for the love of god!)
3. With the engine OFF, shift the tranny into first gear.
4. Rotate either wheel by hand and check that the other wheel rotates in the opposite direction.
5. If the wheel you're not turning does not rotate, your diff is either damaged or has been swapped.
The above was taken from the service manual and it's paraphrased.
Old Oct 1, 2006 | 04:58 PM
Default Re: type r tranny ???'s (umop-apisdn)
thanks for the help
Old Oct 6, 2006 | 06:31 PM
BoostedB16EJ's Avatar
i have a type r trans in my car. i can burn thru 2nd and 1/2 thru 3rd. TWO patches all the way through
Old Oct 6, 2006 | 07:41 PM
Bjorn20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by umop-apisdn &raquo;</TD></TR><TR><TD CLASS="quote">
unless im just an idiot, why would the other wheel turn the OPPOSITE direction? Wouldnt you want it turning the same direction? Isnt that the design of the "parking brake" for dodge intrepids, so the vehile wont move?
Old Oct 6, 2006 | 08:25 PM
StylishDOHC's Avatar
Default Re: type r tranny ???'s (Bjorn20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bjorn20 &raquo;</TD></TR><TR><TD CLASS="quote">unless im just an idiot, why would the other wheel turn the OPPOSITE direction? Wouldnt you want it turning the same direction? Isnt that the design of the "parking brake" for dodge intrepids, so the vehile wont move?</TD></TR></TABLE>
uleiro
May 20, 2008 01:10 PM
BXk24ek9
Feb 28, 2007 08:27 AM
SPEED123
Nov 18, 2006 07:47 PM
bracket 4 life
Apr 26, 2005 09:52 AM
Soku1kcivic
Apr 16, 2002 04:21 PM
