wastegate flange???
Old Jun 4, 2007 | 04:06 PM
homicydalboy's Avatar
Default wastegate flange???
Okay I am steping up the setup in my car quite a bit. The manifold and wastegate are like the only things that I kept from the last setup. Well since I am looking to push about 25is psi I have been told that I am going to run into problems with the wastegate only being a 38mm. So my question would be. Can I take my manifold to a shop and have them cutoff the 38mm flange and weld a bigger one on and step up the wastegate. I am wanting to do this to save money due to the fact I would have tpo buy a new manifold wastegate downpipe. So is it possible??
Old Jun 4, 2007 | 05:52 PM
NJIN BUILDR's Avatar
Default Re: wastegate flange??? (homicydalboy)
Or add another 38mm gate.
Old Jun 4, 2007 | 06:12 PM
Jared's Avatar
running a lot of boost you dont need a big wastegate. you only need a lot of wastegate when you want to turn that turbo down.
k9n
Feb 3, 2009 05:09 PM
kabaroo
Jan 4, 2005 01:45 PM
1RMDave
Nov 16, 2004 02:17 PM
NyQuiL
Jul 15, 2003 11:14 PM
