moroso oil pan gasket???
I have the moroso oil pan just wondering what gasket to use?honda oem, or does moroso make a gasket oil pan gasket..thanks in line four site said that best used with oem honda gasket.
I prefer using Toyota Black FIPG w/o any oil pan gasket. Make sure that all surfaces are completel clean and wiped with a clean rag with brake cleaner. Use a generous bead with the provided tube cone and wing shaped tube squeezing thingy. Make sure you install it immediately and don't make it sit and get tacky. Let it cure over night before adding any oil to the crankcase.
-Joe
-Joe
I had problems with the moroso pan not sealing with the stock gasket because of the flat pan rails vs the stock gasket design, so i cleaned both surfaces thoroughly and used only hondabond as a gasket, worked great.
Re: (Jared)
Which Moroso Pan you talking bout? the oem style or 5 quart one?
If Oem, just use the oem gasket with just Honda bond on the 4 corners...where the oil pump and rear main seal meets up to the block...
then i just hand tightn them down to where they just barley sandwich together...been doing it for years on oem and moroso pans...no leaks here..
Re: moroso oil pan gasket??? (racin jasin R)
looks dry to me thanks to honda bond , oem gasket ,and lock tight.i will try 20psi when i get some race gas see how it hold then!
