blow off valve help
Old May 31, 2007 | 08:34 AM
Moto_340's Avatar
Default blow off valve help
searched has found nothing need help. The guy that had the turbo before me was running 15 psi I am now running 10 psi do you think I need to adjust the blow off valve I here it venting but not loud.
Old May 31, 2007 | 01:22 PM
mahatma's Avatar
Default Re: blow off valve help (Moto_340)
what kind of bov?
Old May 31, 2007 | 01:39 PM
awdgsx96's Avatar
Try softening it just a little bit
Old May 31, 2007 | 02:08 PM
da_dude's Avatar
Adjust it to the point where there is no compresor surge and no bov leaks then you should be good. You shouldn't worry about the bov is not loud enough. As long as it do what it is suppose to do then it's all good.
Old May 31, 2007 | 03:28 PM
Moto_340's Avatar
Default Re: (turb20_vtec)
thanks for the help
Old May 31, 2007 | 07:43 PM
teddy_dc2's Avatar
had same problem boosting 7psi on t3/t4 .57 trim, no cat back and weak vac line cause bov to barely go off, kept hearing a multi pitch sound, thought it was cool at first but then realize it was compressor.
just make sure your bov vac is strong enough. after i fix the two, it was pretty loud. mines was a blitz dd by the way.
Old Jun 1, 2007 | 08:26 PM
Moto_340's Avatar
Default Re: (teddy_dc2)
trying to figure out what mine is going to search It's blue that's all I know lol bought it used came with my kit.
Old Jun 2, 2007 | 05:42 AM
teddy_dc2's Avatar
any pix? where are you tapping the vac source? or do you think it's the bov itself? as long as it releives pressure it's fine.
Old Jun 2, 2007 | 06:26 PM
Moto_340's Avatar
it relieves pressure but was set up for 15psi I was just wondering since I am running only 10psi I should adjust propably so.
Old Jun 2, 2007 | 06:29 PM
Moto_340's Avatar
Default Re: (Moto_340)
can some one IM me and tell me how to post up a pic of the blow off valve wondering what brand it is and if I have to use pack washers I thank so.
autowrench07
Aug 24, 2008 03:13 PM
JDMB20TDA
Apr 25, 2006 05:53 AM
Scubster
Jan 27, 2005 08:33 PM
KeithGSR
Jun 29, 2004 04:58 PM
sleepy
Jul 4, 2002 04:54 PM
