idling problem
Old Jun 3, 2007 | 12:09 AM
vietelement's Avatar
Default idling problem
i just turbo'd my car and now its idling all weird. when i start up my car it'll rev all the way up to 3k and then later on when the car warms up, the rpm will bounce frmo 1200 to like 1800 and it'll just bounce while in neutral. My friend was tellin me something about a missing link, but i don't know how that works, or how to install one?
i drive a 99 civic d16y8. is there a certain missin link i need to get or are they all the same, and once i get one how would i install it ?
Old Jun 3, 2007 | 09:06 AM
Default Re: idling problem (vietelement)
bump.. anyone know ?
Old Jun 3, 2007 | 09:08 AM
g23_ej1's Avatar
i think the first thing you should've told us is what kind of turbo kit you have and most importantly what kind of engine management are you using? i take that you're most likely using an FMU..?
how does it drive? running rich? checked all your vacuum lines?
Old Jun 3, 2007 | 09:56 AM
he_who_corrupts's Avatar
the missing link helps with the the bouncing and if you have a check engine light on. its either that or you just gotta get it tuned and it should stop.
but id say just try the missing link its cheap and will probably help out a lot
http://inlinefour.com/missinglink.html
Old Jun 3, 2007 | 10:17 AM
ABK's Avatar
ABK
Default Re: idling problem (he_who_corrupts)
expletive the ghetto ****. Spend $300-400 and get your car tuned right...
Old Jun 4, 2007 | 06:24 PM
Default Re: idling problem (ABK)
well its running on uberdata, and its running on a td04h with greddy downpipe. and we have tuned it pretty well, when we run it lean in the lower rpm.. it'll start but then later on will sputter and die out but the idle won't bounce as much but it'll still jump around.
and yes i do have a check engine light on
Old Jun 4, 2007 | 08:02 PM
g23_ej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietelement &raquo;</TD></TR><TR><TD CLASS="quote">well its running on uberdata, and its running on a td04h with greddy downpipe. and we have tuned it pretty well, when we run it lean in the lower rpm.. it'll start but then later on will sputter and die out but the idle won't bounce as much but it'll still jump around.
and yes i do have a check engine light on</TD></TR></TABLE>
im sorry but if it does that then you dont have it tuned well at all..
Old Jun 4, 2007 | 10:01 PM
ABK's Avatar
ABK
Default Re: idling problem (g23_ej1)
Let's start with the codes you are throwing....
Old Jun 4, 2007 | 10:59 PM
indicajones's Avatar
yeh cant tune a car the right way with it throwing codes. check your idle ari control valve?
Old Jun 5, 2007 | 04:14 AM
2redstars's Avatar
if your using uberdata, you dont need a missing link. it sounds like a vacum leak. check all your hoses on that go to and from your intake manifold
thericepatch
Nov 21, 2008 08:45 AM
nicktagz
Sep 24, 2006 05:38 PM
FastNFurious
Jun 7, 2003 05:39 PM
blkDOHCsol
Feb 19, 2002 10:10 PM
