Full race downpipe used for AFI ramhorn???
Do you even PLEBE R8?
Does anyone know/ have experience with the full race b series prostreet 3" downpipe (for ramhorn style) used on a non full race ramhorn manifold? Ive searched thru past threads and havent found any info regarding whether the designs are close enough to be able to use it on say my AFI ramhorn.
Re: Full race downpipe used for AFI ramhorn??? (ForceFed_Motorsports)
I'm sure there would be not much of modification you have to do to make it work. I suggest using V-band on the downpipe and your exhaust housing for ease of installation.
Re: Full race downpipe used for AFI ramhorn??? (V-SPEC 1)
The v-band option is definately a good idea, and the more i compare my current 2.5" design to the full race i think it will work just fine. Just curious if anyone else has used it on there non full race setup with success.
if u dont already have the DP, then i wouldnt go out and buy it.
If ur not getting a DP w/ ur mani, then have one custom made so it truely fits.
i ♥ my honda
Global Mod
Global Mod
Your still going to have to add a test pipe or cat so you will most likely be able to make up any slack or off-centernes there. You have to remember the DP's for GT series turbos are a little different then the standard non-gt housings.
Re: Full race downpipe used for AFI ramhorn??? (White Smoke)
True, i already have my setup together. Been running it for about a year now, but have wanted to have a 3" downpipe put in instead of my current 2.5". Im not running a cat and it already has a 3" flex pipe that starts off the 3" exhaust so maybe ill just have the same shop cut it off at the flex and just redo it. Because of lack of equipment a 3" downpipe wasnt an option at the time.
Re: Full race downpipe used for AFI ramhorn??? (Mr HYDE)
I cant find him, last i heard he was banned on here
I dont think they have a website either and i dont have his number.
i ♥ my honda
Global Mod
Global Mod
Arizona Forced Induction
1.888.999.AZFI
Try hitting them up on these forums.
http://www.win-fab.com/forum/index.php
Or on K20a.org http://www.k20a.org/forum/forumdisplay.php?f=75
1.888.999.AZFI
Thanks, ill give him a call and see how much they charge for a dp. Im a cheap ***
turbodano
12-11-2009 09:53 AM
