Ok need some help..............
Old Jun 3, 2007 | 05:32 PM
civic_jdm16's Avatar
Default Ok need some help..............
OK I have a T3/T4 turbo..... and it can be liquid cooled...... My question is were do I run thease lines to???? I know they are for antifreeze, but were do I want to hook them up to the cooling system??????? Plz Help
Old Jun 4, 2007 | 10:06 AM
inspyral's Avatar
Most people either run them inline with the throttle body heater lines, or tap places like the water crossover pipe and block coolant drain plug. It's pretty straight forward. Do a search and you'll find plenty of threads with pics.
Old Jun 4, 2007 | 02:07 PM
Default Re: (inspyral)
thanks for the help.....
I am maybe thinking about the flow..... will the floe make a differance????????
Old Jun 5, 2007 | 12:07 AM
Default Re: Ok need some help.............. (civic_jdm16)
OK bump for this one.... I think I have a good Idea!!!!!!!!! (I THINK)
Ok on 88-91 civic/crx rad, there is a place to run a coolant line.....
Now would the flow be correct if I would put a T in a the coolant temp sensor,
and run it through the turbo back to the rad????????????? thats my best bet right now......
Modified by civic_jdm16 at 11:04 AM 6/5/2007
Old Jun 8, 2007 | 05:45 PM
Bump for some help>>>>> dose anybody think this will work.....
Old Jun 8, 2007 | 06:30 PM
b00steds0l's Avatar
Yes, that will work fine. Also the flow direction doesn't matter. All that does is that there are no leaks.
Old Jun 8, 2007 | 06:47 PM
Topdawgg's Avatar
some people run one to the bottom of the rad and to the thermostat housing... they say its cooler there..
I just ran both of mine to a line by the thermostat... it might not be as cool, but its still a closed, pressurised line..
Old Jun 9, 2007 | 05:45 PM
Default Re: (Topdawgg)
Thanks guys!!!!!!!
XSIintegra
Aug 27, 2008 06:03 PM
evild16
Jun 17, 2008 08:25 AM
high boosted rex
Aug 24, 2006 07:03 AM
SlowSOHC-T
Jul 25, 2006 06:44 AM
DIY_Racing
Dec 18, 2002 09:25 PM
