oil pressure psi
Old May 31, 2007 | 07:14 PM
aryiman98civic's Avatar
Default oil pressure psi
i have a turbonetics 60-1, .63 a/r and .60 trim. what is the oil pressure this turbo should have? i can't find out how much psi it can handle. please help. thanks
Old Jun 1, 2007 | 02:29 AM
da_dude's Avatar
All I know is honda motor will provide too much oil for the turbo needs. Only one way to know is to call up Turbonetics and ask them.
Old Jun 1, 2007 | 08:39 AM
called up turbonetics and they said their turbos are not set up for restictors, so i am going to get one anyway. im running a -3 line from stealth and im not sure to get the adjustable restrictor or the non adjustable restrictor
Old Jun 1, 2007 | 09:26 AM
da_dude's Avatar
I would just get the non adjustable restrictor from http://www.atpturbo.com/Mercha...e=OIL and call it a day. With the adjustable one you will need a pressure guage so you won't restrictor too much and feed too much oil. Just my 02 cent.
Old Jun 1, 2007 | 10:10 AM
GSROWNSU's Avatar
i thought turbonetics turbos already had the proper oil restrictors in them?
Old Jun 1, 2007 | 02:34 PM
needmypass's Avatar
Default Re: oil pressure psi (aryiman98civic)
the answer to question is and i simply took this from the website LMFAO "Oil PSI should be at least around 20-30 PSI at idle and 50-70 psi under boost."
hotshot100
Apr 14, 2010 05:10 PM
nightlife88
Oct 17, 2007 05:42 PM
greasemonkee
Aug 25, 2007 03:46 PM
Dominick331
Apr 5, 2006 02:13 PM
ProjectLudeSiR
May 12, 2004 09:53 PM
