H23 NO START
Old May 29, 2007 | 05:02 AM
jwyndsdime's Avatar
Default H23 NO START
I have my engine in and ready to go. I went to start it and I am not getting spark at the plugs or voltage to the fuel pump. You guys have any idea? I don't have the oil pressure sensor in, would that have anything to with it?
Thanks!
Old May 29, 2007 | 07:23 AM
RC000E's Avatar
Default Re: H23 NO START (jwyndsdime)
Solid CEL, main relay clicking or no, is the ecu in the car, ignition switch? No fuel pump voltage indicates an issue early in the system, should be a very easy problem to track down.
Old May 29, 2007 | 11:59 AM
jwyndsdime's Avatar
Default Re: H23 NO START (RC000E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">Solid CEL, main relay clicking or no, is the ecu in the car, ignition switch? No fuel pump voltage indicates an issue early in the system, should be a very easy problem to track down. </TD></TR></TABLE>
CEL? After work I am going to check on the relay. Thanks.
Old May 29, 2007 | 05:14 PM
RC000E's Avatar
CEL=Check Engine Light
You should hear two clicks when you put the key in the on position, the first click right as the engine light comes on, then a second click as the light goes off. If the lights stays on, or there are not 2 distinctive clicks with the on and off event, then you have a problem.
Old May 29, 2007 | 07:14 PM
jwyndsdime's Avatar
ohh ok we call them MIL's not CEL's
anyways, I got the car running, it was the oil pressure sensor. but now my problem is I have no oil pressure :-(
Old May 29, 2007 | 07:18 PM
RC000E's Avatar
Default Re: (jwyndsdime)
Oil pressure sensor definitely has d*ck to do with fuel pump voltage. Sounds like you need to get your story straight.
808civi
19
May 29, 2016 05:42 PM
Kenneth77488
Dec 23, 2013 02:17 PM
lazylegs15
Sep 14, 2008 10:20 PM
chad
Oct 6, 2003 04:56 PM
01IntegraSE
Mar 20, 2003 05:56 PM
