faulty wastegate?
Old Jun 3, 2007 | 10:24 AM
Pr0ject93hb's Avatar
Default faulty wastegate?
so i recently purchased a turbo kit for my eg. im running as ls vtec and now have a 60 trim t3/t4 turbo set up i got from a homies shop. its not exactly name brand, but he has the kit on his car and its a decently good set up (and the price was awesome). so we did the install ourselves and i started the car and it was of course loud as hell since i was running open downpipe. i took it to the muffler shop and had them do a 2.5 set up all the way back.
so then i start the car when im about to leave there and its still loud as hell, but like i have an exhaust leak. so we take it home and start messing with it only to find out that the dump tube off of the wastegate is spitting air out of it all the time. now my understanding of a wastegate is that it is only supposed to open when the turbo spools more pressure than the spring inside is rated to handle, thus allowing you to run the psi you want (ie 8lbs). so it should be letting air out all the time right? i mean, especially not at idle.
so my motor shop (ls motorworks) tells me its a bad wastegate and to upgrage to a tial (which i planned on doing before tunning anyways) but i want to make sure its the waste gate and not something else.
since it was a cheaper kit it wouldnt suprise me if the wastegate is bad, and its warrentied anyways. i know you get what you pay for and all that.
but any help would be much appreciated!! thanks.
Old Jun 3, 2007 | 10:41 AM
mitsuman's Avatar
Default Re: faulty wastegate? (Pr0ject93hb)
How much air is coming out? Does it feel/sound like its completely open? Are all vaccum lines hooked up properly?
Also do you have the ring in there? Is it installed correctly?
Old Jun 3, 2007 | 10:44 AM
NJIN BUILDR's Avatar
Most of the time (at least on a Tial) it's because someone left out the valve seat on the waste gate.The copies use the same thing.If you go to Tials site http://www.tialsport.com you can see a pictue of it.
Old Jun 3, 2007 | 11:00 AM
Default Re: faulty wastegate? (mitsuman)
im missing the ring. it didnt come with one
Old Jun 3, 2007 | 11:01 AM
ima go look through all my install trash and see if i can find the valve seat, im pretty sure thats what im missing
Pr0ject93hb
Jun 3, 2007 11:25 AM
h22a_junkie
Apr 24, 2007 05:08 PM
94turbodelsol
Jul 28, 2005 11:42 AM
x2gold
Apr 26, 2003 05:47 PM
