b16 turbo or h2b
Old Jun 3, 2007 | 11:42 AM
ohio_twin_ser's Avatar
Default b16 turbo or h2b
okay i have been trying to decide for a while now what to do i have a 93 dx coupe that i swaped a b16 into now im in a strugle between slightly building the b16 and turboing it or just usingthe tranny i have and get an h22a withthe h2b conversion kit and turboing that... but if i do the h2b im not going to do the rods or pistons kinda just wondering if the h2b and the b16 will be fairly matched after all is said and done even though i wont be able to push as many psi in the h22 as the b16 and the b16's red line is so much farther than the h22...? i also have been looking for some time threw the forums and havent seen any thing about how the h2b kit handles turbos. i have yet to see any one who has posted a forum on the subject if any one knows of one please let me know so i can read it ,thanks. im basically ready to either order a **** load of parts for the b16 and start the build or buy a h22 and some parts... some suggestions would be nice... thanks not totally sure if this should be in this section of h-t ...
FOR THE B16
cp pistons/ and rings
eagle rods
ferrea valves
blox springs /retainers
4 750 injectors
255 walbro fuel pump
hondata s300
clutch
drive shaft/axel kit
gt3037r turbo
i/e/h
Old Jun 29, 2007 | 09:56 PM
Winlight's Avatar
Default Re: b16 turbo or h2b (ohio_twin_ser)
i am also wondering about the h2b and turbo.maybe ill try it and let you know
Old Jun 29, 2007 | 10:00 PM
93CX's Avatar
Default Re: b16 turbo or h2b (Winlight)
If you already have the B16, boost that.
Old Jun 29, 2007 | 10:12 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
h2b's are fun but if u want boost go with that. i have a h2b in my wagon its fast but I LOVE BOOST..
Old Jul 6, 2007 | 05:01 PM
DangerMouse's Avatar
H2b!! You'll be making the same power with a non turbo h2b as a turbo'd b16.
There are plent of turbo H2bs on here. All you have to do is SEARCH.
https://honda-tech.com/zerothread?id=1558926
https://honda-tech.com/zerothread?id=1723209
https://honda-tech.com/zerothread?id=1553157&page=1
https://honda-tech.com/zerothread?id=1681064
There are more.
Also go here http://www.quartersportsdrag.c....html
Old Jul 6, 2007 | 05:50 PM
sohctodohc's Avatar
Default Re: b16 turbo or h2b (Turbo_D)
...are you series? the h2b pushes no more horsepower than a h22 which is no more than 190 to the wheels. yes it has torque. unlike the b16a but at 8-10 psi depending on what turbo he uses he can be pushing 300 horsepower with the b16a.
Old Jul 6, 2007 | 06:43 PM
CELERITAS's Avatar
didnt you guys hear the news h2b converions add an instant 200whp at idle.
Old Jul 6, 2007 | 07:11 PM
HiProfile's Avatar
Default Re: (CELERITAS)
Lol...
If you want to match an NA H2B with a turbo B16, you do what a automotive engineer would do - go with a smaller turbo (like a GT28R or a 50trim T3), then have >25% more whp while still having good response (low lag). But be warned, uou may have to do the most amazingly crazy thing that a HT member could do - push something smaller than a t3/t04e 50trim OVER 10psi wiht a bigger MAP sensor.
The problem with the way people see lag, throttle response, and a small turbo @ higher psi VS a big NA motor: you only need a few psi at lower rpm to shoot over the big NA motor's torque number, and from then on, you're set even if torque drops off.
Old Jul 6, 2007 | 10:23 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
boost the b16 if you want more power. or do the h2b and get less power for around the same amount of cash.
Old Jul 6, 2007 | 11:18 PM
Do some reading here https://honda-tech.com/zerothread/1998426
Old Jul 8, 2007 | 07:59 PM
sohc-8's Avatar
he said the B16 will be mild built. he can reach 400whp with that setup. stock h2b won't come close to that, and with turbo, maybe he could but i doubt the stock ringlands will like it. i suggest you just build that b16.
Old Jul 9, 2007 | 02:39 PM
lunatics209's Avatar
Default Re: (sohc-8)
well my friend did make 210 whp and 162 torque on a stock jdm h2b. thats unbelievable but i seen it right on the dyno too.
Old Jul 9, 2007 | 06:25 PM
blinx9900's Avatar
Default Re: (Mr Wonderfull)
boosted b16
Old Jul 9, 2007 | 06:41 PM
GetawayInMoscow's Avatar
Default Re: (blinx9900)
Boost the B16.
See the time in my sig? I did that on my boosted B16 on STREET TIRES. I'd like to see a H2B Civic run mid 12's on street tires.
Old Jul 9, 2007 | 08:55 PM
Default Re: (GetawayInMoscow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">Boost the B16.
See the time in my sig? I did that on my boosted B16 on STREET TIRES. I'd like to see a H2B Civic run mid 12's on street tires.</TD></TR></TABLE>
Seen it..
and i was talking about a stock b16
Old Jul 13, 2007 | 07:14 AM
ALL-MoToR559's Avatar
i say all motor h2b...i/h/e good tune..easily 12s like nothing...h2b is the way to go...and for the people...of course it's going to still be aroud 200 hp..all you're changing is the tranny...but a more aggressive tranny is what the h22 needs to unleash it's powers!!
Old Jul 24, 2007 | 03:51 PM
h2b turbo get as much info as you can so i can ask you when i do mines. b16 waste of money. go with something big. and for you guys that say h22 can't make 200 horse, i just seen my friend's h2b make 210 horse and 160 torque. ******* monster all stock. man how about turboing that thing.
Old Jul 24, 2007 | 07:12 PM
Default Re: (Turbo_D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_D &raquo;</TD></TR><TR><TD CLASS="quote">
Seen it..
and i was talking about a stock b16 </TD></TR></TABLE>
You better believe mine was stock, unless you want to count ITR cams.
Old Jul 24, 2007 | 07:27 PM
Kyle R's Avatar
H2b Turbo would be ideal. I guess it depends on how much money the OP has/wants to spend?!?!?
ohio_twin_ser
20
Jun 7, 2007 08:34 AM
Crazyfraze
12
Mar 22, 2005 09:25 PM
coot_er
Jan 24, 2005 07:25 PM
calihondategra19
Jul 31, 2004 05:03 PM
quik sol
Sep 15, 2003 04:28 AM
