Hybrid Turbos?
Old Jun 4, 2007 | 08:01 PM
cimo463's Avatar
Default Hybrid Turbos?
I been doin some research because i am about to go turbo and my friend referred me to Hybrid turbos. Has anyone had any problems with these turbos? Just curious...tried to look for it...but no luck.
Thanks
Old Jun 5, 2007 | 06:14 AM
twkdCD595's Avatar
Default Re: Hybrid Turbos? (cimo463)
First off I am not the best person on here with wording so I hope I can help you out a little here and not confuse you more but here it is in a small nutshell. Cause you are asking a very broad questions that can cover pages and pages of information over various topics (so read as much as you can here cause this is by no means all of it, rather this is bearly scratching the surface).
Probably 75% (maybe more) of the turbocharged cars on this board are using hybrid turbochargers, so yes work and work quite well. As far as problems with them, that mostly gets into manufacturing and some are better than others obviously. Garrett, Turbonetic, Borg Warner, Holeset, Precision (garrett based), ITS, Full-race, etc... there is a ton of turbo manufacturers/ distributors offering turbochargers... too many for me to go through briefly in this thread. I think I named most of the popular quality units you will find here but there is more I am sure I missed... and there is alot cheap substandard junk on ebay so be aware of who manufacturers the turbo your looking at and do some research to make sure they are quality.
Anyways.
A "hybrid" turbo uses parts from two different families of turbochargers to create a completely new turbo for various reasons. Take for example a T3/T4. This turbo uses T3 turbine parts combined with T4 compressor pieces to make a turbo that fits a certain horsepower and displacement range better.
(check out http://auto.howstuffworks.com/turbo1.htm or http://www.turbobygarrett.com/....html for some basics if this part lost you or you want to learn more.)
With alot of people here wanting to maximize the powerband/ output (which varies of course) the hybrid units can be used to cater to our small displacement and high rpm motors. Increasing boost responce (smaller turbine section) while still maintaining the high volume output and efficiency benefits (bigger potential hp that does not fall off at high rpm) of a larger compressor is kinda the general idea for us IMO.
I am sure others can add some more information I am overlooking or did not detail in my breif summary.
Modified by twkdCD595 at 9:32 AM 6/5/2007
Old Jun 5, 2007 | 06:21 AM
93supercoupe's Avatar
Default Re: Hybrid Turbos? (twkdCD595)
thats was an excellent summary.
Saying u want a hybrid turbo is like throwing a rock into an ocean, theres ALOT of different ones and ur gonna have to research what other people have used to get similar goals.
Old Jun 5, 2007 | 06:29 AM
twkdCD595's Avatar
Default Re: Hybrid Turbos? (93supercoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">thats was an excellent summary.
Saying u want a hybrid turbo is like throwing a rock into an ocean, theres ALOT of different ones and ur gonna have to research what other people have used to get similar goals.</TD></TR></TABLE>
exactly what I was thinking, in fact I edited in a little more information after reading it agian but I had to try to contain my thoughts cause it is WAY to much information for a simple post.
Old Jun 5, 2007 | 04:57 PM
cimo463's Avatar
Thanks guys...That helps alot....My friend made it seem as Hybrid was a brand..But i know what is means now...Thanks!
Sloshy
Apr 11, 2008 04:35 AM
DenzComp
Jun 16, 2007 04:32 PM
RACEPAK
Oct 9, 2005 11:14 AM
1BadDC2
Mar 20, 2004 02:49 PM
SCD16A6
Jan 11, 2004 06:33 PM
