what FPR to use with dual bosch pumps?
I have paxton fpr and my pumps blew the ******. I was thinking about getting aeromtive 13101. With stock fpr my gauge reads 90psi at idle. I know weldon works real well but who sells them. I'm using stock feed for return with RC 1000cc injectors.
Re: what FPR to use with dual bosch pumps? (Turbocivic94)
You know what might be a good idea for your set-up? this- http://www.nipponpower.com/pro...3E%29
because it has "solid piston design with no diaphragm will prevent from rupture or failure" but check it out, you may not be comfortable with it, not sure if anyone here uses it.
Holy **** 90psi at idle thru 1000cc injectors. How does that thing idle???
You need some top of the line **** that can hadle that much fuel going thru it. Aeromotive is one of the best I guess. Are you sure that stock feed line is big enough to return that much fuel (I have no idea)?
Re: what FPR to use with dual bosch pumps? (ABK)
It shouldn't be tearing the diaphragm on any of the regulators. We run the weldon stuff to 150psi on our alcohol cars.
1 Post
Re: what FPR to use with dual bosch pumps? (agrn93ls)
that nippon aint going to work your pressure will be 2 high at idle. im using a1000pump with stock feed as return with aromotive FRP & idles at 40psi can go lower if i want. . i also have rc1000cc,s at idle i got the injectors basically closed as is just to get it to idle somwhat smooth 90psi would be harsh i would think
Re: what FPR to use with dual bosch pumps? (ALL IMPORT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL IMPORT »</TD></TR><TR><TD CLASS="quote">that nippon aint going to work your pressure will be 2 high at idle. im using a1000pump with stock feed as return with aromotive FRP & idles at 40psi can go lower if i want. . i also have rc1000cc,s at idle i got the injectors basically closed as is just to get it to idle somwhat smooth 90psi would be harsh i would think</TD></TR></TABLE>
I just bought aeromotive 13101 fpr. I was wondering if I can bore the return on regulator. Has anyone done this?
1 Post
i didnt bore my hole & just put a hose fitting on & sliped it over the stock feed. done. i did bore my fuel rail.
aslo thats the same 1 i have . fuel is chillin at 40spi
vtecmissle
02-19-2006 11:47 PM
integra-modder
10-04-2002 02:33 AM
uneekcrx
05-09-2002 04:59 AM
