how much boost
Old May 30, 2007 | 02:19 PM
trex352's Avatar
Default how much boost
i have a 99 integra ls just got a turbo kit and i am not sure how much boost it can handle safely can someone helpit also has 157,000 miles
Old May 30, 2007 | 03:08 PM
ziptie's Avatar
Default Re: how much boost (trex352)
i know for a fact you can only run 11.9820428 psi
Old May 30, 2007 | 05:24 PM
95dc2teg's Avatar
Default Re: how much boost (jagoff)
what size turbo, injectors, etc etc?
Old May 30, 2007 | 06:19 PM
Topdawgg's Avatar
worst thread ever....
ive said it before, and ill say it again.... ITS NOT A BOOST LEVEL , its how much power that motor can make with that particular setup...
you could run 15 psi of boost on a t28 turbo and not make alot of power, or 15 psi on a t3/t4 and make 300whp
do some more reading before you boost anything
Old May 30, 2007 | 06:46 PM
uberhaulin's Avatar
im with top dawgg
Old May 30, 2007 | 07:10 PM
BrockNB's Avatar
Default Re: (Topdawgg)
x3
Old May 30, 2007 | 07:21 PM
95jeremie's Avatar
Default Re: (BrockNB)
x4
Old May 30, 2007 | 07:35 PM
numbnuts22715's Avatar
Default Re: (95jeremie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95jeremie &raquo;</TD></TR><TR><TD CLASS="quote">x4</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrockNB &raquo;</TD></TR><TR><TD CLASS="quote">x3</TD></TR></TABLE>
Great answers guys
but seriously, it all depends on the power.
psi on one turbo can make more or less power than the same psi on another.
Its all about the power that it makes, not on how much psi it takes to get there.,
Old May 30, 2007 | 07:39 PM
95jeremie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">worst thread ever....
I've said it before, and ill say it again.... ITS NOT A BOOST LEVEL , its how much power that motor can make with that particular setup...
do some more reading before you boost anything</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">
Great answers guys </TD></TR></TABLE>
why do you say that?
the question was answered
you just said the same thing that topdawgg said
so regardless your are x5
I'm just lazy
Old May 30, 2007 | 07:41 PM
95jeremie's Avatar
added a new choice for ya, there ya go
Old May 31, 2007 | 02:08 AM
atec's Avatar
Default Re: (numbnuts22715)
It all depends on that your stock mapsensor cant read above 11psi
Old May 31, 2007 | 04:11 AM
nonvtecallmotor's Avatar
Default Re: (atec)
Its all about the tune.
Old May 31, 2007 | 08:11 AM
Schister66's Avatar
Man U FTW
The amount of boost/power you can make depends on a few things....
1. Dont ever rate anything by the amount of boost you can run, that is one of the signs that someone is newer to the scene...they ask how much boost can i run....that is such a variable question because no 2 setups are the same.
2. What management are you running? what fuel are you tuning on? What turbo are you running?
On most stock b series turbo setups, people stay in the upper 200, low 300 range in order to keep them relatively safe....it doesn't matter how much boost it takes to get there as long as the turbo is still efficient, your IATs are low enough and your tune is good....
Old May 31, 2007 | 08:46 AM
93supercoupe's Avatar
Default Re: (Schister66)
these threads should be deleted.
Bring it to get tuned and ask them.
Old May 31, 2007 | 09:14 AM
Schister66's Avatar
Man U FTW
Default Re: (93supercoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">these threads should be deleted.
Bring it to get tuned and ask them. </TD></TR></TABLE>
Even though i agree, threads like this still have a point IF they're worded correctly and give all the necessary information. General threads that ask "how much boost?" are ridiculous and should simply be deleted because there just isn't enough info to make any kind of judgement....
I believe that there are enough of us who are capable of helping IF the OP is willing to help him/herself...
Old Jun 6, 2007 | 09:04 PM
NTX
Guest
Posts: n/a
subscribed
spluvs2install
Mar 15, 2008 10:55 AM
ser13
Dec 23, 2007 10:07 AM
mugentype-r
Nov 2, 2005 01:42 PM
ras
May 3, 2005 09:14 AM
Sam1am26
Nov 26, 2004 06:51 PM
