Tial 44mm wastegates, What spring do they typically come with?
Just curious what they come with, I dont have the box it came in handy..
thanks
thanks
Re: (cilver sivic)
The V44 wastegate that came in my full-race stage2gtac kit was a .7bar
I need a small red wastegate spring (PM if you have one for sale) to bump me up to 1bar because my greddy aspec boost controller doesn't want to build more then 22psi.
I just read where the V44 gate comes with a racing valve so it is ok to run leaded gas. That was good to know and also if anyone doesn't know much about these you have to combine small and large springs to get 1bar or higher i just found out.
Re: (sp00led)
I don't think it is standard what spring they come with.
My 44mm came with a 1 bar ( two springs, one small about 5 psi, the other large about 10 psi)
I still have the 10psi one sitting around.
Re: (sp00led)
I believe it comes with the spring the you need, I bought mines from nolimitmotorsport and they asked me what spring did I need your best bet is 2 open it and check what color you have good luck
Re: (ek_bape)
there is no default spring it what ever the person who ordered it has in stock. You can order any 44mm and stock it with any spring you want. up 1.5bar
sPaRk'iT
09-10-2004 10:16 PM
