91 realtime auto wagovan shift position switch issues?
Old 11-07-2010, 06:59 AM
Foowee's Avatar
Default 91 realtime auto wagovan shift position switch issues?
I'm having an issue with the shift position switch in my 91 wagovan. When I turn the car off and put it in park the "P" light in the cluster doesn't always light up. While this happens I can't get the key out of the ignition.
Well, I checked Majestic and it doesn't look like the switch is still available new. I'll call my local dealer tomorrow. For now, I'm wondering if I can just mount a spring loaded rocker switch in the console n tap the green/white wire n run it to ground? Has anyone here had to do this before?
Old 10-25-2012, 04:02 AM
wasp9166's Avatar
Default Re: 91 realtime auto wagovan shift position switch issues?
i have the same issue, 489 views for you, 117 for me
this may be something no one knows about
Old 10-25-2012, 05:39 AM
91 EF DX's Avatar
just eliminate the switch
Old 10-25-2012, 06:13 AM
Former User's Avatar
Have you tried adjusting the switch?
Old 10-25-2012, 07:14 AM
artiecubz's Avatar
I'm having the same problem with my mom's Del Sol. The key is always getting stuck in the ignition.
I can get it out though, if I disconnect the battery. I'll have to give that switch adjustment a try.
Old 10-26-2012, 05:06 AM
wasp9166's Avatar
how would you get the key out?
no,i'll try this before i order a new switch, ty
continuity would be anything but 0? volts or ohms?
Old 10-26-2012, 10:59 AM
wasp9166's Avatar
according to this
http://www.ehow.com/how_4537480_test...ontinuity.html
if any of these posts reads anything other than 0 ohms the switch is toast, or can't be adjusted to read 0 , is this correct?
Old 10-26-2012, 03:36 PM
ef yu's Avatar
If you look at the pics above posted by RonJ@HT the console switch is the problem.
Heres what i did to fix the switch on my mothers integra.
Removed the switch, removed all plastic covers ( be careful there is a tiny pin ball thats inside) to reveal the contact points for when the switch goes to P, R , N , D , ETC . I noticed that the contact points were dry and did not really make good contact.
I cleaned it up really good. once i did that, i added solder to each contact point to kinda bring it up, or level it up, so that the switch will actually make contact with it. Once finished with that, i lubed it up with electric grease. Put it all back together and haven't had the problem come back. (its been a year).
Sorry i don't have any pics. I spent 5 minutes trying to look for that switch online but i cant find any and I am too tired to keep looking.
Old 10-27-2012, 04:44 AM
wasp9166's Avatar
Originally Posted by wasp9166
according to this
bueller?
Old 10-27-2012, 06:39 AM
Any readings less than 50 Ohms or so should be fine.
fin781
06-16-2011 08:30 AM
Civic Racer X 7
02-25-2011 12:31 PM
west nile
03-10-2007 12:39 PM
Pengo
03-17-2002 10:05 AM
Quick Reply: 91 realtime auto wagovan shift position switch issues?
