turbo dx??
Re: turbo dx?? (xjdm94x)
http://www.homemadeturbo.com
he did a d15b2 with a 14b turbo.. ran 14.1 with home made water injection kit and a very expensive stand alone management system
Re: turbo dx?? (Corporal-Jeff)
I'm building one my self as well. Just bought the turbo today, not totally stock though: I'm doing the MPFI swap before hand. I will run about 6-8 psi of boost, more then likely 7. I will not be using the all mighty $1k fuel management systems for I do not know how to tune with them.
Re: turbo dx?? (TorteX)
why would i need to swap to mpfi? I have no problem with the 2 injectors cuz like I said...I'm going to utilize mf2 (2 extra 440's) which is well enough to suppose up to 7psi.
Jeff-
Jeff-
Re: turbo dx?? (Autocratic_1st_Gen)
It can be done www.homemadeturbo.com but if you are going to fork over a $1k for a turbo set up, you should just as well run a mpfi swap. It will make you alot more powerful, and at the same time you will more then likely be a lot safer from blowing anything then the dpfi.
Plus you will not be running a nice $1k engine management system, with that you are just about safe from any type of damage if you know how to tune it. That is probably why it works for them. I do not know of any other DPFI turbos, if that tells you anything.
[Modified by ijjz, 5:25 PM 9/17/2002]
Re: turbo dx?? (ijjz)
i'm not using any standalone..the only thing i'll be using is MF2 to control the extra 2 440's..it's been doing on many volkswagons and rx7's..i don't see reason why it won't work on this project
Jeff-
Jeff-
hmm.. so u guys think i should do multi point fuel injection over dual?? cuz i'm in the process of lookin for a ef and boosting the d series
No More Civic
05-10-2002 11:03 PM
