climate control busted!
man, right before my swap my fan and heater and everything else in the center climate control doesn't work. the fan doesn't turn on but all the lights work. so when it gets foggy i just pull over and wait. what can i check to get this working. i live in hot socal with no AC, fan or vents!!! ahh, help!!
did you check to make sure that the wire harness did not come loose?
I am not sure if the climate control has two harnesses one for fan control and one for lighting, so it is possible. If it is not that you might as well check the wires with a multimeter while you have it pulled out.
Edit: My climate control does not let me select where it blows (always in face, no defroster or feet) so I might have a similar problem.
[Modified by incubus, 9:28 PM 10/26/2002]
Ransom
Jun 25, 2004 03:12 PM
