Swap Time- What else do i need???
ok im gettin ready to do a swap (b16a in 89 civic std hatch) what other parts do i need or u recomend i get???
I know i need:
b16a (complete swap: tranny, ecu, axels, etc.)Hondamotorsonline.com
motor mounts- has sport
wire harness- has sport
timing belt- oem honda
manual tranny fluid- oem honda
motor oil- mobil syn
thats all i know
I also need to know what kind of tools u guys use for the swap
Thanks in advance!
I know i need:
thats all i know
Thanks in advance!
Re: Swap Time- What else do i need??? (RaceFacer)
just have extra cash around...when i got my sohc zc, the pulleys were alll rusted and the dizzy was cracked, and the oil pan was dented, but it was cool, i just took them off my other **** filled four banger gone 1 banger
Re: Swap Time- What else do i need??? (altoid)
ohh yah ur gonna need coolant as well...umm...tools...make sure you have a good breaker bar...lemme think...i think u need some more ish...it seems the list never ends...check and see that ur hubs fit i beleive they do...someone can varify that for me on here....
[Modified by RaceFacer, 1:24 AM 10/30/2002]
Re: Swap Time- What else do i need??? (ZC_CRX)
look at my site... from when we did b16 swap into a dpfi 90 dx... http://www.angelfire.com/dc/oregonimport/tools.html starts with the tools you will need and everythign else with pics and all..
Re: Swap Time- What else do i need??? (projecthybrid04)
dual point
90' integ clutch cable #22910-sk7-a02
90' integ throttle cable #17910-sk7-a03
95' del sol V-TEC water pump #19200-p30-003
timing belt #14400-pr3-004
crank seal #91212-pr3-003
cam seals #91213-pr3-004 x2
cv shafts for a 89 integ
Hi Im STD one point six is directly on the money, you will need dx\si knuckles and hubs, std hubs are too small for the axles to fit through,
i know when doing my b16 i had the engine in, in 3 hours by myself
the wiring took me some time though,
tools you will need, a basic set of tools should do the job, you dont need snap - on or mac to work on cars, it just helps
19 mm deep socket for the lug nuts
32 mm socket for the hub nuts - you'll need a breaker bar most of the time to loosen theese.
17mm to losen the lower control arm bolt
10 mm for upper control arm bolt cover
17 mm for upper control arm bolt
10 mm to take odd brake line brackets
8 milimeter punch to take the bitch pin out of the shift linkage
19 mm for engine mount bolts
A hammer to losen the steering arms from the upper control arm when you change them, after you take the upper control arm cover off and take the UCA bolt off it will still stay there until you clock it with a hammer or mallet.
there are other sockets i know but these are a few main ones
a good set of pry bars will help you
keep your whits about you, i have a bad temper when i cant get something to work right and it dosent solve anything to get mad,
keep your work area organized and a friend to help you always makes it easier
good luck with the swap
ps i just turned 18 and i have done all the work on my car myself, so dont let older ppl tell you that you cant do it
Hope that helps
also if you get stuck on something dont hesitate to email me danbus5@hotmail.com
Dan,
Hope that helps
Dan,
SOHC_DK.
07-27-2004 01:51 PM
p3s7
10-15-2003 10:45 AM
