Timing Questions
Old 01-09-2003, 06:33 PM
Red_Si's Avatar
Default Timing Questions
ok, i know that when i put on my sohc vtec head and do the timing that i need to set the crank pulley and #1 piston to TDC. my question is, when the new head comes out of the shop how do i set it to TDC or whatever i'm supposed to set it to??? or does it come the way i should put it onto the block??? i know i can't just put it on because when it's started it might bend valves and what not. Basically how do i set the head so nothing goes wrong???
Old 01-09-2003, 07:27 PM
Red_Si's Avatar
Default Re: Timing Questions (Red_Si)
bump, need to know, anybody?
Old 01-09-2003, 07:40 PM
d357r0y's Avatar
your helms manual should tell you..
put on the cam gear and line up the marks.
put crank at TDC.
install timing belt.
Old 01-10-2003, 01:54 AM
slowassgsxr750's Avatar
Default Re: Timing Questions (d357r0y)
line up the timing marks on the head,there an arrow on the plastic cover,spin the cam sprocket till the up mark is up,then line up the timing line on the sprocket to the arrow on the cover
Old 01-10-2003, 11:15 AM
Red_Si's Avatar
Default Re: Timing Questions (singleslamrex)
i don't have my helms manual on me right now. plus its an a6 block with a y8 head, does that make any difference??? I didn't see any marks on the cam gear thats why i was wondering. can anyone show me a mark on a stock gear??? also if i find out where the mark on the stock gear is what other mark do i line that up with??? is there a mark on the plastic tb cover to align it correctly??? thx for the help.
BTW a pic of a stock cam gear and mark on it would be helpful, i think i see one on mine but i'm not sure.
Old 01-10-2003, 06:14 PM
Red_Si's Avatar
bump, read above post
Old 01-10-2003, 09:10 PM
the DR.'s Avatar
i dont have a picture of a cam gear, but the stock gears have 2 marks on them, they are across from each other, you put the gear til where it says "UP" is up then you line the 2 marks parallel with the head.. sorry its hard to explain..
Old 01-10-2003, 11:36 PM
gvillehnut's Avatar
A few pics and help on timing here.
https://honda-tech.com/zerothread?id=376377
Old 01-11-2003, 03:36 PM
Red_Si's Avatar
Default Re: Timing Questions (black90b16)
ok, i got it all now!!! but one more question, how do i rotate the gear when the head is off the car (as in sitting on my dresser)??? do i crack the bolt on it slightly loose and rotate or what???
Old 01-11-2003, 08:18 PM
gvillehnut's Avatar
What do you mean? There is a small key that holds the cam gear in place on the cam. When lining all the marks up you rotate the cam gear and the cam together. No need to untighten. And depending on how far you need to rotate it you might have to give it some umph to open/close some of the valves to get it positioned right.
[Modified by black90b16, 12:23 AM 1/12/2003]
Old 01-11-2003, 08:27 PM
altoid's Avatar
with that in mind you may just wanna do head at tdc then do pistons at tdc...don't wanna be bending valves at 1 rpm...people will laugh
Old 01-12-2003, 02:45 PM
Red_Si's Avatar
well the head is sitting on my dresser in my room. i need to rotate it to tdc but the gear doesn't wanna move??? how do i rotate it???
Old 01-12-2003, 03:02 PM
Jeef's Avatar
put some muscle into it... or if you feel like it you can take your valve train off rotate and reassemble beign careful to not move the cam... but thats too much work imo... oh yeah, and i'd set it pretty close before it goes on and then double check it once its mounted... and bring your # 1 piston to TDC before you put the head on... makes life a lot easier...
[Modified by Jeef, 7:05 PM 1/12/2003]
Old 01-12-2003, 03:14 PM
Red_Si's Avatar
Default Re: Timing Questions (Jeef)
ok, you just said to take the valvetrain off and rotate it that way but don't move the cam??? that's impossible the gear is attached to the cam. ??
Old 01-12-2003, 04:21 PM
Louie B.'s Avatar
I think he meant don't lift the cam out of the head. Just stick a socket and ratchet on the cam gear nut and tighten. Once the bolt is tight, it will spin the cam gear and cam.
I posted these on a previous post, but here you go:
crank position:
Cam gear position:
close up of cam pointer:
this is on A6 block w/ A6 head, but Y8 head should be similar.
Old 01-12-2003, 05:09 PM
Red_Si's Avatar
Default Re: Timing Questions (thumpu77)
ok i got it thanks everyone
j4s0n1337
11-27-2011 11:34 PM
spooncivic01
02-19-2008 05:44 PM
HybridRacer69
11-09-2007 03:10 PM
kornerk12
05-21-2007 11:45 AM
bushfreakz
09-13-2006 10:58 AM
Quick Reply: Timing Questions
