What is this??? (massive)
I might be wrong on this but i just wanted to make sure, i went through the wiring diagrams and i believe this goes to the tach...am i right? or way off....
Re: What is this??? (shorty91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorty91 »</TD></TR><TR><TD CLASS="quote">haha rag racing! im pretty sure it does</TD></TR></TABLE>
nah, thats to cover my "secret" motor. ha, i wish, its a 70hp piece of ****.
1 Post
No.
That 2pin connector that those wires lead to is for the ignition coil. One wire is positive, and the other is a ground. That has nothing to do with the tach. On the 7pin connector for the distributor, there should be 2 white wires (if it's an Si or HF), one fatter than the other. This fatter white wire sends the RPM signal to the ECU. I'm not sure exactly where/how the tach pics it up at...
Re: What is this??? (MrTodd)
if your installing a tach, take off the dizzy cap and unscrew the positive post to the coil, put your wire in thier and screw it back down. works like a charm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrTodd »</TD></TR><TR><TD CLASS="quote">No.
That 2pin connector that those wires lead to is for the ignition coil. One wire is positive, and the other is a ground. That has nothing to do with the tach. On the 7pin connector for the distributor, there should be 2 white wires (if it's an Si or HF), one fatter than the other. This fatter white wire sends the RPM signal to the ECU. I'm not sure exactly where/how the tach pics it up at...</TD></TR></TABLE>
sorry, i stand corrected, but i do know you hook up aftermarket tachs to that blue wire (2pin connector)
1 Post
Re: What is this??? (the DR.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the DR. »</TD></TR><TR><TD CLASS="quote">
sorry, i stand corrected, but i do know you hook up aftermarket tachs to that blue wire (2pin connector)</TD></TR></TABLE>
Ooops, than I am wrong.
it would probably alot cleaner to just splice into the blue wire leading to the stock tach, and alot less wiring to do.
its the #1 pin on the 8p connector on the back of your cluster. just look for the solid blue wire.
that is to say if your installing an aftermarket tach.
Re: What is this??? (90civichbsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi »</TD></TR><TR><TD CLASS="quote">it would probably alot cleaner to just splice into the blue wire leading to the stock tach, and alot less wiring to do.
that is to say if your installing an aftermarket tach.</TD></TR></TABLE>
Its an std, so it doesnt have a tach, im getting a cluster from the si which has the tach, can someone explain how to hook it up? And also, while taking my stock cluster, i found a amber piece of plastic screwed in on top of the cluster, if i want to change the color of my gauge lights is this what i would change?
sorry but u are wrong.. the blue wire is the "tach" wire.. yes they goto the coil as well, but it also goes to the tach as well.. again.. the blue wire from that 2 pin connector is the tach wire..
if u have a std, or DX model without a tach.. the wires are already there.. just plug in the gauage and the tach will start working
Re: What is this??? (JonGP4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonGP4 »</TD></TR><TR><TD CLASS="quote">sorry but u are wrong.. the blue wire is the "tach" wire.. yes they goto the coil as well, but it also goes to the tach as well.. again.. the blue wire from that 2 pin connector is the tach wire..
if u have a std, or DX model without a tach.. the wires are already there.. just plug in the gauage and the tach will start working </TD></TR></TABLE>
so just plug it into where my gas gauge and water temp plug in is now?
Re: What is this??? (94prelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94prelude »</TD></TR><TR><TD CLASS="quote">
so just plug it into where my gas gauge and water temp plug in is now?</TD></TR></TABLE>
WTF? just take out ur gauge cluster, and put in the one from at Si with a tach.. if u car is 88-89 then make sure ur gauage cluster is from a 88-89 if its 90-91 then u need one from 90-91.. they plug right in.. no need for any other wiring as long as u keep the years i just said right.
if u car is 88-89 then make sure ur gauage cluster is from a 88-89 if its 90-91 then u need one from 90-91.. they plug right in.. no need for any other wiring as long as u keep the years i just said right.</TD></TR></TABLE>
how does everyone hide their wires and where do they put the tach?how to wire in the tach to the coi
OutLuDeD
03-01-2003 07:50 AM
