90 Honda CRX Si....Sunroof problem.
My sunroof from my 90 CRX Si opens fine but has a very hard time closing. Only way i can close it is if a keep clicking the switch time and time again. Sometimes i have to click it like 100 times to move it about a centimeter to close. Anyone have any suggestions? Thanks
Re: 90 Honda CRX Si....Sunroof problem. (Targa250R)
So both of you guys are giving me the same answers? It has something to do with the switch itself you think? If so, what part would i need to order from the Honda dealership. Those bastards will charge about $180 to simply take the time to look at the sunroof which is a joke, if i can do it myself, i will.
Re: 90 Honda CRX Si....Sunroof problem. (SkylineGTR)
call a junk yard and try to find a used working switch. you might want to try the classifieds here on HT.
my buddy had so many problems with his crx sun roof so we tried to fix it got it to move kinda, but in the end he just broke the track...once he was parting out the car i took his switch and sure enough my sunroof was doing what his was doing before....check the switch first.
1 Post
Re: 90 Honda CRX Si....Sunroof problem. (mansonclubpuir)
Whenever my sunroof is hard to close it always been one of these three things. Tracks and cables need lube. Tracks and cables have debris and crap stuck in them and causing it to jam, or it was extremely cold out.
I've never had a problem with my switch. Of course now I've just jinxed it so the switch will crap out in the next couple of days.
Re: 90 Honda CRX Si....Sunroof problem. (4crx4me)
yea mine had that problem too... i just used some silicon spray **** and sprayed the **** out of the rails and sparyed it as far back as i could... now it closes ok
I used to have the exact same problem with my HB, and here is the solution:
first of all, it's your switch, nothing more than that.[*]remove your switch[*]open it, it's pretty simple, you'll figure it out[*]examinate closely the order of things, if possible, take a pic for future reference.[*]once you have it open, you'll notice a small metal part that rocks one side or the other. that metal part makes the contact to either open or close your sunroof.[*]i'm 105% sure, the closing contact on your switch is dirty. get a small piece of sand paper, or just scrub it with a sharp object, to remove the dirt.[*]once you've done that, re-asemble the switch as it was b4[*]plug it and test it. voila, problem solved.
if i had pics, i would post them. that happened about 6 years ago, and i found my way of fixing up the switch like that until i got a replacement from the j-yard.
good luck all!!!
good luck all!!!
Re: (civicsir.com)
mine works good now!! I opened the sunroof and cleaned off all the old gunky oil and grime then I closed it and it closed fine, now I think my throwout bearing is going out, damn that sucks.
Re: (I Gotta Question)
OK, i just disconnected the sunroof switch from the wiring. Their is the black switch part and the white connecting part, i need to disconnect these two and just clean the inside of the switch?
And the sunroof opens with no problem but closing doesn't work until every 30 attempts at closing it. What i mean is, it doesn't budge little at a time, it only closes all the way in about every 30 attempts. So i'm thinking their has got to be some bad connection with the closing portion of it.
Re: (SkylineGTR)
OK guys, i cleaned the switch and saw exactly what you were talking about and guess what, it works fine now. I want to thank all of you guys, especially civicsir.com who really explained it step by step. You guys saved me about $100 cause i was going to take it to a shop. Now it works great cause of the help you guys gave me, thank you so much. This site is great.
there is also a step by step walkthrough to fix that problem here.. also has pictures: http://www.crxsi.com/resources...2.htm
Location: I told you to wait in the truck in Texas, United States
Re: (Custom Rex)
If you have Adobe Acrobat,
This article is highly informative..
check out:
http://wwwx.cs.unc.edu/~hays/crx/crxsunroof.pdf
Modified by 88DXCRX at 2:16 PM 9/19/2008
check out:
Re: (coz)
what do you suggest. Mines also doing the same thing. I'll do the switct thing and greaseh thing also. So what grease u suggest??
Re: (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">mugen grease. it will give your sunroof more HP.</TD></TR></TABLE>
" God Damn Your One Funny Bastard ! "
Re: (Rex-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rex-Si »</TD></TR><TR><TD CLASS="quote">
Re: (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">mugen grease.</TD></TR></TABLE>
They sell that at the sticker shop dont they ?
Re: (Rex-Si)
They sell that at the sticker shop dont they ?</TD></TR></TABLE>
lol the sad thing is, mugen actually makes grease
Re: (temp)
lol the sad thing is, mugen actually makes grease </TD></TR></TABLE>
No **** ?
No **** ?
