no power to starter signal fuse...
would taking off the ignition cylinder matter with the starter signal fuse not gettin any power? I lost the key and needed to move the car but this happen. All the engine bay fuses get power and the fuses under the dash too, the starter gets power too. The ecu blinks one time too when i turn the switch but on the dash the battery light wont go off, no check engine light either, no codes.
Re: no power to starter signal fuse... (TIRENECK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TIRENECK »</TD></TR><TR><TD CLASS="quote">All the engine bay fuses get power and the fuses under the dash too, the starter gets power too. The ecu blinks one time too when i turn the switch but on the dash the battery light wont go off, no check engine light either, no codes. </TD></TR></TABLE>
I'm getting the same thing. Brand new battery and my dad & I checked the starter and it pushes out and spins at the same time. The starter signal wire makes my voltmeter show voltage when we turn the key. And the car does nothing. I hear some electrical buzzing. Could it be that our distributors are bad??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TIRENECK »</TD></TR><TR><TD CLASS="quote">would taking off the ignition cylinder matter with the starter signal fuse not gettin any power? I lost the key and needed to move the car but this happen. All the engine bay fuses get power and the fuses under the dash too, the starter gets power too. The ecu blinks one time too when i turn the switch but on the dash the battery light wont go off, no check engine light either, no codes. </TD></TR></TABLE>
ur asking how to hotwire it?
carpenterkyle
03-19-2014 04:30 PM
oneprelude
04-26-2009 08:49 AM
