can't find this torque spec anywhere.
Skoobie no more...
Re: can't find this torque spec anywhere. (ZCed89hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZCed89hatch »</TD></TR><TR><TD CLASS="quote">until it stops leaking</TD></TR></TABLE>
ok so i have to put the tank back in... turn the car on look for leaks then take the complete tank back out..... you OBVIOUSLY have never dropped your gas tank.
Re: can't find this torque spec anywhere. (HatchBox)
when i did mine i tourqued it pretty tight. with new crush washers it should seal up okay. that's the banjo bolt correct? i know the banjo bolt on the fuel filter tourques to 132 IN. lbs which is 11 ft. lbs i believe. use whatever name you want but keep the avatar. my wife makes me find it for her everytime i'm on the board. she loves it.
Skoobie no more...
Re: can't find this torque spec anywhere. (mr. carpenter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter »</TD></TR><TR><TD CLASS="quote">when i did mine i tourqued it pretty tight. with new crush washers it should seal up okay. that's the banjo bolt correct? i know the banjo bolt on the fuel filter tourques to 132 IN. lbs which is 11 ft. lbs i believe. use whatever name you want but keep the avatar. my wife makes me find it for her everytime i'm on the board. she loves it. </TD></TR></TABLE>
haha that was my goal to please the wifes of honda-tech'ers
Charlie Moua
10
09-22-2003 11:59 AM
