B16 question
B16 question
I was wondering if anyone knows were i can get NEW OEM piston rings and a full engine gasket set? I need to get this asap. Im about to do a rebuild on my EF B16, so help me get her pullin hard again.
Andru
Andru
if your doing things with all OEM parts and sticking within factory limits you can get the gaskets for the 00 civic Si (b16a2). the only thing that doesnt match from that engine is the electronic stuff
thats the same engine, for the most part, for the 00 civic si, its actually a b16a3 instead of the a2
i always refer to the civic si engine parts as less confusion for most idiots working the counter at your local parts place. too many times i have had to explain to the people which engine with the Del Sol. when saying the 00 Civic Si there isnt any confusion
but yes the rings and gasket kit will work. also i would advise replacing the bearings, rod and crank, since you pulling it apart anyway.
Re: (silverkorn)
but were can i get a full gasket set at? FOr a good price? I usually get killer deals through Napa but its still about 200 bucks. But please some one help me out.
Andru
Andru
Re: B16 question (hughesl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hughesl »</TD></TR><TR><TD CLASS="quote">I used teg type R piston rings for my build.
The diff between the b16 and b18 is stroke.</TD></TR></TABLE>
i would only say that for the piston heads, there are some other things that wont swap from the B18 to a B16. and i doubt your going to gain much by going with a type r pistons rings. if anything i would go aftermarket
