how can you tell if your car is overheating if the temp gauge is broken - Honda-Tech - Honda Forum Discussion
Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988 - 1991)
Reload this Page >
Old 04-16-2005, 05:57 PM
civais's Avatar
Default how can you tell if your car is overheating if the temp gauge is broken
how can you tell if your car is overheating if the temp gauge is broken. I think I have a small wiring problem, temp gauge goes to hot when ever I put the left turn signal on. really started to do weird things after I replaced the temp sensor.
civais is offline
Old 04-16-2005, 06:02 PM
SiR Inspired ED7's Avatar
Default Re: how can you tell if your car is overheating if the temp gauge is broken (civais)
i'd fix the needle, other than that i dont know...
SiR Inspired ED7 is offline
Old 04-16-2005, 06:09 PM
civais's Avatar
Default Re: how can you tell if your car is overheating if the temp gauge is broken (88 Crx Si)
i do not even want to think about getting uder there with a multi meter and trying to find the short. my overflow tank does not overflow or boil as I have seen in other cars that overheat
civais is offline
Old 04-16-2005, 10:21 PM
egtwincam's Avatar
you can measure the voltage at your ect. engine coolant temp sensor. its a 2 wire sensor on the head. plug in some paper clips and check the voltage. when its normal operating temp it should be about .5 to . volts. any less than that it is overheating..
egtwincam is offline
Old 08-13-2015, 07:33 PM
gomer124's Avatar
when mine overheats, it always idles high then low very noticeably something wrong lol
gomer124 is offline
Old 08-13-2015, 09:20 PM
Touching My Member
.Manny.'s Avatar
10 year old thread bump?
Jesus can't even match this dude's resurrection skills.
.Manny. is offline
Old 08-13-2015, 10:16 PM
PHANTOM MENACE
24TEN's Avatar
Not a newb either, he's an 03
24TEN is online now
Old 08-14-2015, 03:11 AM
Freemananana's Avatar
Maybe he sub'd to this thread and finally checked his email.
Also, I'd just install a $20 aftermarket temp sensor if you are worried. Run it through the firewall and drop it in your cup holder until you get everything sorted out.
Freemananana is offline
Kevins89notch
21
03-09-2016 01:25 PM
Thekid184
09-14-2015 01:46 PM
White_EG1
General Discussion and Debate
19
08-27-2015 04:27 AM
monkey_boi
11-08-2008 01:03 PM
Quick Reply: how can you tell if your car is overheating if the temp gauge is broken
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
