Qs about Codes
Qs about Codes
Hi. Changed my oil this morning and decided to check if my ECU (PM5) was throwing any codes. I'm driving a stock 90 CRX DX with rebuilt D15B2. This is what I read from it...
blink - pause - blink - pause - 19 blinks - pause - 20 blinks - and then it repeats itself but with only 1 blink between the 19 blinks and 20 blinks.
From what I've searched I've found that I have the following codes:
Code 1: Oxygen Sensor "A"
Code 19: Automatic Transmission Lock Up Control Solenoid Valve
Code 20: Electric Load Detector
So, for Codes 1 and 20, I know to check my Primary Oxygen Sensor and then check all my grounds. But the thing that gets me is Code 19. I've got a manual transmission and I'm getting a code regarding an automatic transmission? What gives? I didn't try to reset my ECU though. Gonna do that at lunch and see if any codes disappear or if more will appear! All I have to do to reset my ECU is disconnect the negative from the battery, correct?
Thanks in advance! And yes, I searched!
Re: (progress)
Check your fuses for code 20, make sure none are blown.
Use these to help you out:
Page 1: http://www.we-todd-did-racing....3D%3D
Page 2:http://www.we-todd-did-racing....3D%3D
Page 3:http://www.we-todd-did-racing....3D%3D
KiD Fr0m Da 516
08-02-2004 06:36 AM
