After the tranny swap my car runs horrible..ECU codes 10 and 14
I just reinstalled an A6 into my 88 HF. Now it seems like i have fuel cut. ECU is throwing code for IAT and IAC. when i press the throttle the engine will rev then drop and rev then drop over and over quickly.
It ran perfect before I took it out. I replaced the throttle body b/c the idle control vavle was bad.
Any suggestions?
Any suggestions?
Re: After the tranny swap my car runs horrible..ECU codes 10 and 14 (md88hfcrx)
I believe you swapped the IAT and IAC plugs try switching them and see if that helps
Re: After the tranny swap my car runs horrible..ECU codes 10 and 14 (Super Chicken)
thanks super chicken and warrick, that was the problem.
del soler
09-10-2004 02:06 PM
