please dont kill me (dpfi to mpfi) help.
W95 gives me a hard-on
1 Post
Sup, I know this has been covered a million times. I have gone through 7 pages of search and couldnt find nothing that can help me.
Here's the deal
ZC motor into a 88 civic. PG7 ecu
Problems
Car cranks but it doesnt turn on. Fuel pump does not turn on or primes. No spark.
I have tripple checked my wires, (this is my second car, first one worked like a charm). I have run injector wires (A1, A3, A5, A7)straight from the ecu. C1 and C2 moved to B10 and B12. C1 C2 out to cylinder posistion sensor.
I have changed the main relay but no luck.
On the main relay there are two yellow/white wires that supplies the power to the ecu. I get 11 volts. There are two green/black wires that aslo come from the ecu but I dont know if they are positives or Negatives. A black/yellow wire that brings power when ignition is on. The only wire that has me confused is a blue/white wire that comes from the (B13)ecu that should be grounded all the time ( I say this because I tested on another car ) but it is not. I checked for continuity from the relay to the ecu and its good. I also get no power from the yellow/black wire that supplies power to the injector and pump ( all this tested at the main relay box)
The weird thing was I carnked the engine and the ecu thru a 15 code which I know it was the white wires at the distributor. Switch them around, and now I dont get any more cels but still wont turn on.
What else you guys think could be wrong that the ecu is not turning on the injectors or firing?
This **** has me puzzled.
I swear this is my last dpfi /mpfi conversion
Here's the deal
Problems
Re: (civic889802)
had the same prob with mine used a jumper wire from fusebox to pin 4 on
main relay fixed the prob but not really the right way i had a wiring prob under dash involving black /yello wire from computer to relay maybe this can help?
3.point.2
02-02-2006 01:02 PM
crx88fast
12-30-2005 05:19 PM
