so much smoke
Re: (crxsi8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsi8 »</TD></TR><TR><TD CLASS="quote">im running no cat and i have black smokes!..don't know why!</TD></TR></TABLE>
that is what a cat does..it catches un burnt fuel= black smoke..
Re: so much smoke (Br0KeNCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Br0KeNCRX »</TD></TR><TR><TD CLASS="quote">, If it is why would it smell like fuel, and alot of smoke come out? Also isnt that really really bad if that happened.</TD></TR></TABLE>
the water turns to moisture, white smoke. the fuel doesn't all get burned because of the moisture in the cylinder, gas smell. if the intake manifold gasket goes bad, that's not so bad. hope your head isn't warped, that's bad. are you leaking any water? did you drive the car hot anytime?
Re: so much smoke (mr. carpenter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter »</TD></TR><TR><TD CLASS="quote">
the water turns to moisture, white smoke. the fuel doesn't all get burned because of the moisture in the cylinder, gas smell. if the intake manifold gasket goes bad, that's not so bad. hope your head isn't warped, that's bad. are you leaking any water? did you drive the car hot anytime?</TD></TR></TABLE>
or the head gasket...
Re: so much smoke (kulangot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulangot »</TD></TR><TR><TD CLASS="quote">
or the head gasket...</TD></TR></TABLE>
roger that.
roger that.
