1989 Civic Brake lights not working...is there a switch near the brake pedal? - Honda-Tech - Honda Forum Discussion
Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988 - 1991)
Reload this Page >
Old 06-14-2006, 06:50 AM
babybreese's Avatar
Default 1989 Civic Brake lights not working...is there a switch near the brake pedal?
I checked all three bulbs ( rear wondow brake light and the two in the back ) and the fuses, everything is OK. When I hit the pedal, the lights don't come on. So I am not sure what to do next...I dread taking it to a mechanic for this.
I have heard it could be a mecahnical switch that is triggered by the brake pedal, or it could be a hydraulic switch.
Can anyone help me with this. Does this sound like a switch probelm? Where is it located?
Any help would be beyond helpful. I have looked around under the dash by the pedal but don't see anything.
babybreese is offline
Old 06-14-2006, 07:31 AM
jlicrx's Avatar
Default Re: 1989 Civic Brake lights not working...is there a switch near the brake pedal? (babybreese)
jlicrx is offline
Old 06-14-2006, 08:48 AM
babybreese's Avatar
Well, that is where the switch is located but I cannot for the life of disconnect the 2-P connector from thebrake switch. Access is horrible, I can just barely get a grip on the connector, and it does not want to pull straight off. Is there a clip or something to push?
I saw breaks in the insulation on the 4 wires going into the P-2 that exposed the wire inside. I separated them so they were not touching and checked but nothing lit up.
I am thinking I have to take it into the shop unless I am missing something obvious.
thanks very much for the diagram jlicrx
Old 09-05-2006, 06:52 AM
HamiltonRex's Avatar
Default Re: (babybreese)
yes on the one side of the wiring there is a clip you push in.. Then it will pull straight off, then just jump the switch with a piece of wire, and if the lights work, your switch was bad..
Make sure your horn/stop fuse in the underhood fuse box is good.
HamiltonRex is offline
Old 09-05-2006, 07:21 AM
jackinthetrunk's Avatar
Default Re: (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">
Make sure your horn/stop fuse in the underhood fuse box is good.</TD></TR></TABLE>
check that fuse!
jackinthetrunk is offline
Old 08-16-2017, 07:38 AM
Hey bud, are you able to provide a picture where yours is located? I cant seem to find mine. Im starting to think i dont even have one!
Kiidkiid10 is offline
Old 08-16-2017, 12:33 PM
Keyboard Humorist
4drEF's Avatar
I don't think he's going to respond.
You replied to a thread that hasn't had any activity since 2006.
If you need help, it is totally acceptable and HIGHLY RECOMMENDED that you start a new thread rather than posting to old ones.
4drEF is offline
Outrun
26
09-02-2018 04:36 PM
vfeezy
10-13-2017 08:13 AM
Tim32
Honda CR-V & Element
07-15-2017 12:19 PM
TomCat39
12
05-02-2017 08:09 PM
Ray Satomi
15
01-07-2017 03:42 PM
Quick Reply: 1989 Civic Brake lights not working...is there a switch near the brake pedal?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
