1988 Civic, 1.5l - Check Engine Light @ 60-70 MPH - error code 4.
Hello, All.
I have a 1988 Honda Civic, 2DHB that runs great, except...
It stalls. After warm up. Get a nice Yellow "Check Engine" light as well.
I can reproduce the issue.
IT's only when it is moving; it can idle all day long.
Get it up to about 60-70 MPH for a few seconds to a few minutes, the "Check Engine" light comes on.
Then, it starts to run rough.
Then, it dies.
Wait 5 seconds - it restarts fine.
Get it above 55 MPH - it repeats the same behavior.
So...
Pulled the HAZARD fuse to reset the ECU.
Start it up - no error codes - clean. So far, so good.
Run it down the highway - BINGO - "Check Engine" light, and it dies.
Coast int a parking lot, and there's an error code - 4: TDC Crank sensor.
So...
Measured continuity on the terminal sets D and E, then B and C. 550 Ohms
Checked for continuity to body ground on D and E terminal individually - infinity. Continuity does not exist.
So...next step would be to use the PGM-FI Wiring harness to check the main wire harness, but I don't *have* a PGM-FI test harness.
That said...
I decided to check continuity on the body - just my two test leads connected, touch to the body on points very near each other - infinity. Continuity does not exist.
I *should* read 0, and do when I connect the leads together.
So, do I have a crappy tester, and do I throw a new distributor into this car? Or am I looking into wiring issues?
Any advice is appreciated.
Thanks,
Austin Civic
Then, it dies.
So...
So...
That said...
Thanks,
Austin Civic
$cat /dev/urandom
Re: 1988 Civic, 1.5l - Check Engine Light @ 60-70 MPH - error code 4. (austincivic)
i would say if any of the tests fail according to the manual you are using, then you should replace the distributor. i had a code 9 forever, and tried everything. the only thing that fixed it was a new distributor. they are notorious on these cars for failing.
you can find them on ebay for $150 shipped. ive had one for 2 years now and it has worked fine..
Re: 1988 Civic, 1.5l - Check Engine Light @ 60-70 MPH - error code 4. (sanimalp)
Try something simple first like cleaning off your rotor.
Re: 1988 Civic, 1.5l - Check Engine Light @ 60-70 MPH - error code 4. (thenick)
"Try something simple first like cleaning off your rotor."
Heh - did that. FWIW - it's got a brand new cap, rotor, and wires on it.
$cat /dev/urandom
yeah thats where i started. did the wires, plugs, cap and rotor. nothing. it was a waste of money. put a new distributor on it and it worked just fine.
it says right in the manual i have, that if continuity does not exist with a body ground on d or e individually, as you tested it, to replace the distributor assembly. if you want i can post a pic of it.
youve done all the simple stuff it seems. the only thing left is to bite the bullet and pay $150 for a new distributor. dont bother with a junkyard one because its probably either just as bad or going to go bad. i made that mistake also, and it left me stranded 20 miles from my house when the bearing in the junkyard distributor seized. luckly my timing belt didnt break.
