Is A.C. possible?
Is A.C. possible?
I have a crx si... I got the car with out a.c. no dash controls, lines , and compressor... i bought another si shell for the parts and it has everything for the ac... can i swap everything to mine and will it work? thanks
Re: Is A.C. possible? (clutchpoppin0723)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clutchpoppin0723 »</TD></TR><TR><TD CLASS="quote">I have a crx si... I got the car with out a.c. no dash controls, lines , and compressor... i bought another si shell for the parts and it has everything for the ac... can i swap everything to mine and will it work? thanks</TD></TR></TABLE>
YEs. Must take everything. Wiring, switch, lines, etc etc etc.
be professional
In theory, yes.
In reality, you may have to replace some components of the system due to leakage and/or moisture contamination - unless you know for sure that the A/C worked properly in the parts shell and has not been tampered with since it last ran.
You will need the compressor, the condenser, all the lines, the A/C wiring harness, the switch, the evaporator dash box and evaporator, and the firewall grommet. There may be some other misc. parts needed as well.
Re: Is A.C. possible? (Targa250R)
yea but even if the panel on mine is with the **** and the parts one is with the buttons... will that still matter?
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clutchpoppin0723 »</TD></TR><TR><TD CLASS="quote">yea but even if the panel on mine is with the **** and the parts one is with the buttons... will that still matter?</TD></TR></TABLE>
If you have a CRX, you should have a push-button climate control. All CRXes had buttons, and all Civics had levers (in the US).
Either way it doesn't matter, since the A/C switch for either control panel is the same (80410-SH3-013). The entire A/C accessory kit was the same for CRX and Civic hatchback (80000-SH3-A13).
be professional
Re: (~sp33~)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~sp33~ »</TD></TR><TR><TD CLASS="quote">didnt the EX civic come with pushbutton?</TD></TR></TABLE>
No.
No.
Re: (Targa250R)
and to do the harness part is the dashboard gotta come out? Basiclly is this a do it yourself thing or do i have to take it to some one?
Re: (Under Con. CrX)
partswise, is the a/c kit on the oem parts site all i need?
http://www.hondaautomotivepart...R+KIT
thanks in advance!
thanks in advance!
be professional
Re: (CERRITOS.562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CERRITOS.562 »</TD></TR><TR><TD CLASS="quote">partswise, is the a/c kit on the oem parts site all i need?
thanks in advance!
You should probably call and ask Majestic (or any other Honda dealer) if any accessory A/C kits are still available for the vehicle, before you go ordering from the site.
But yes, if you could get a hold on a complete kit, it would include everything needed to install the A/C other than refrigerant and oil.
thanks in advance!
coot_er
07-22-2004 01:59 PM
